6" Superlift Question-maybe some pics please
what is the difference between the 6in standard kit and the 6in rockrunner kit?
Pictures would help alot!
thanks
thanks
The only difference is the control arms. They each come in two pieces. On one end, it looks like a screw and is threaded. The other end is like a hollow pipe and is threaded on the inside. You screw one into the other until you get the right lenth. This allows for two things. More flex of the suspension system because they can twist. Adjustability of the suspension because you can thread in the controls arms to pull the axle back, or thread out the control arms to push the axle forward. Also, you can extend the tops and leave the bottom allowing you to increase castor or whatever else you want to do.
BigGameJames
12-22-2007 09:08 AM
PEAKSTRYDE
10-11-2007 04:20 PM
tufamc
05-19-2007 07:13 PM
Amprice4
03-18-2007 02:34 PM
Ramasaur
09-10-2004 07:03 PM
