CODE p1756 HELP!
CODE p1756 HELP!
anyone know anything about this code it has something to do with shift solenoid b performance i guessing something with the transmission. what would cause this code it came on after i got on it pulling into traffic with my power pup on performance
Very common problem. I would suggest replacing the governor pressure transducer and soenoid. Here's some more info
Symptom:
P1756-GOV PRESS NOT EQUAL TO TARGET @ 35 - 40 PSI (DIESEL)
When Monitored and Set Condition:
POSSIBLE CAUSES
OTHER TRANSMISSION DTC’S
INTERMITTENT GOVERNOR PRESSURE SOLENOID
CHECK TRANS FLUID LEVEL AND CONDITION
5 VOLT SUPPLY CIRCUIT OPEN
GOV PRESSURE SENSOR SIGNAL CIRCUIT OPEN
SENSOR GROUND CIRCUIT OPEN
GOV PRESS SENSOR SIGNAL CKT SHORT TO GND
GOV PRESS SENSOR SIGNAL CKT SHORT TO SENSOR GND
GOV PRESS SENSOR SIGNAL CKT SHORT TO VOLTAGE
5 VOLT SUPPLY CIRCUIT OPEN INSIDE TRANS
GOV PRESS SENSOR GROUND CKT OPEN INSIDE TRANS
GOV PRESS SENSOR SIGNAL CKT OPEN INSIDE TRANS
GOV PRESS SENSOR SIGNAL CKT SHORT TO GND INSIDE TRANS
GOV PRESS SENSOR SIGNAL CKT SHORT TO SENSOR GND INSIDE TRANS
GOV PRESS SENSOR SIGNAL CKT SHORT TO VOLTAGE INSIDE TRANS
OIL BURNT OR OIL PAN HAS EXCESSIVE DEBRIS
VALVE BODY
GOVERNOR PRESSURE SENSOR
INTERNAL TRANSMISSION
PCM - 5 VOLT SUPPLY
PCM - GOV PRESSURE NOT EQUAL TO TARGET
432
TRANSMISSION
TEST ACTION APPLICABILITY
1 Turn the ignition on.
With the DRBIIIt, read DTCs.
Note: The Transmission Control Relay may be removed during this test, this
will set other codes. They can be disregarded.
Is the Trip Counter for P1756 displayed and equal to 0?
All
Yes ® Go To 2
No ® Go To 33
2 Turn the ignition on.
Are any other transmission DTCs present?
All
Yes ® Repair all other transmission DTCs before proceeding.
Perform TRANSMISSION VERIFICATION TEST VER - 1.
No ® Go To 3
3 Start the engine.
Allow the transmission to reach normal operating temperature.
Check the transmission fluid level and condition. Refer to the Service information.
Is the fluid level correct and the fluid condition OK?
All
Yes ® Go To 4 No ® Repair as necessary the transmission fluid level and condition. Perform TRANSMISSION VERIFICATION TEST VER - 1.
4 Caution: Apply the parking brake. Start engine. Warm the engine to normal operating temperature. With the DRBIIIt, read the governor pressure.Caution: Apply the brakes. Place the gear selector in Drive. Is the governor pressure above 21 KPa (3 PSI)?
All
Yes ® Go To 5No ® Go To 28. 5 Turn the ignition off. Install a pressure gauge at the governor pressure test port. Caution: Apply the parking brake.
Start the engine. Warm the engine to normal operating temperature.
Read the governor pressure on the gauge in Drive.
Is the governor pressure on the gauge below 34 KPa (5 PSI)? All Yes ® Go To 6 No ® Go To 31
6 Turn the ignition off.
Disconnect the Transmission Solenoid Assembly harness connector.
Check connectors - Clean/repair as necessary
Measure the voltage of the 5 volt supply circuit at the Transmission Solenoid
Is the voltage between 4.5 and 5.5 volts?
All
Yes ® Go To 7
No ® Go To 20
7 Turn the ignition off.
Disconnect the PCM C2 harness connector.
Measure the resistance of the governor pressure sensor signal circuit between the
Transmission Solenoid Assembly harness connector and the PCM C2 harness
connector.
Is the resistance below 5.0 ohms?
All
Yes ® Go To 8
No ® Repair the governor pressure sensor signal circuit for an open.
8 Turn the ignition off.
Disconnect the PCM C1 harness connector.
Check connectors - Clean/repair as necessary.
Measure the resistance of the sensor ground circuit between the Transmission
Solenoid Assembly harness connector and the PCM C1 harness connector.
All
Yes ® Go To 9
No ® Repair the sensor ground circuit for an open.
9 Turn the ignition off.
Measure the resistance between ground and the governor pressure sensor signal
circuit in the Transmission Solenoid Assembly harness connector.
All
Yes ® Repair the governor pressure sensor signal circuit for a short to
ground.
No ® Go To 10
434
TRANSMISSION
P1756-GOV PRESS NOT EQUAL TO TARGET @ 35 - 40 PSI (DIESEL) —
Continued
10 Turn the ignition off.
Disconnect the PCM C1 and C2 harness connectors.
Measure the resistance of the governor pressure sensor signal circuit to the sensor
ground circuit in the Transmission Solenoid Assembly harness connector.
All
the sensor ground circuit.
No ® Go To 11
11 Turn the ignition off.
Measure the voltage of the governor pressure sensor signal circuit in the Transmission
Is the voltage above 1.0 volt?
All
voltage.
No ® Go To 12
12 Turn the ignition off.
Remove the transmission oil pan.
Disconnect the Governor Pressure/Transmission Temperature Sensor harness connector.
Measure the resistance of the 5 volt supply circuit between the Governor Pressure/
Transmission Temperature Sensor harness connector and the Transmission Solenoid
Assembly case connector.
All
Yes ® Go To 13
No ® Replace the Transmission Solenoid Assembly in accordance with
the Service Information.
13 Turn the ignition off.
Note: Check connectors - Clean/repair as necessary.
Solenoid case connector and the Governor Pressure/Transmission Temperature
All
Yes ® Go To 14
435
TRANSMISSION
Continued
14 Turn the ignition off.
Transmission Solenoid Assembly case connector and the Governor Pressure/
All
Yes ® Go To 15
15 Turn the ignition off.
circuit in the Governor Pressure/Transmission Temperature Sensor harness connector.
All
Yes ® Replace the Transmission Solenoid Assembly in accordance with
No ® Go To 16
16 Turn the ignition off.
Measure the resistance between the governor pressure sensor signal circuit and
sensor ground circuit in the Governor Pressure/Transmission Temperature Sensor
harness connector.
All
No ® Go To 17
436
TRANSMISSION
Continued
17 Turn the ignition off.
Note: The Transmission Solenoid Assembly harness connector must be
connected before proceeding.
Measure the voltage of the governor pressure sensor signal circuit in the Governor
All
No ® Go To 18
18 Place the gear selector in Neutral.
With the DRBIIIt, read the Governor Pressure Sensor voltage.
Measure the voltage of the governor pressure sensor signal circuit by back probing at
the PCM.
Compare the voltmeter reading of the governor pressure sensor signal circuit to the
DRBIIIt Governor Pressure Sensor voltage.
Start the engine.
Does the DRB Gov Press Sensor voltage match the governor pressure sensor voltage
on the voltmeter?
All
Yes ® Go To 19
No ® Replace the Powertrain Control Module.
19 If there are no possible causes remaining, view repair. All
Repair
Replace the Governor Pressure/Transmission Temperature Sensor
in accordance with the Service Information.
20 Turn the ignition off.
connector.
All
Yes ® Go To 21
437
TRANSMISSION
Continued
21 Turn the ignition off.
Measure the resistance of the 5 volt supply circuit between the Transmission
Solenoid Assembly harness connector and the PCM C2 harness connector.
All
Yes ® Go To 22
No ® Repair the 5 volt supply circuit for an open.
22 Turn the ignition off.
All
Yes ® Go To 23
23 Turn the ignition off.
All
ground.
No ® Go To 24
24 Turn the ignition off.
All
No ® Go To 25
438
TRANSMISSION
Continued
25 Turn the ignition off.
All
voltage.
No ® Go To 26
26 Turn the ignition off.
All
Yes ® Go To 27
27 If there are no possible causes remaining, view repair. All
Repair
Symptom:
POSSIBLE CAUSES
VALVE BODY
PCM - 5 VOLT SUPPLY
432
TRANSMISSION
All
Yes ® Go To 2
No ® Go To 33
All
No ® Go To 3
3 Start the engine.
All
All
All
Yes ® Go To 7
No ® Go To 20
connector.
All
Yes ® Go To 8
All
Yes ® Go To 9
All
ground.
No ® Go To 10
434
TRANSMISSION
Continued
All
No ® Go To 11
All
voltage.
No ® Go To 12
All
Yes ® Go To 13
All
Yes ® Go To 14
435
TRANSMISSION
Continued
All
Yes ® Go To 15
All
No ® Go To 16
harness connector.
All
No ® Go To 17
436
TRANSMISSION
Continued
All
No ® Go To 18
the PCM.
Start the engine.
on the voltmeter?
All
Yes ® Go To 19
Repair
connector.
All
Yes ® Go To 21
437
TRANSMISSION
Continued
All
Yes ® Go To 22
All
Yes ® Go To 23
All
ground.
No ® Go To 24
All
No ® Go To 25
438
TRANSMISSION
Continued
All
voltage.
No ® Go To 26
All
Yes ® Go To 27
Repair
28 Caution: Apply the parking brake.
Place the gear selector in Park.
Start the engine.
With the DRBIIIt read the governor pressure.
With the engine still running, remove the Transmission Control Relay from the PDC.
WARNING: WHEN THE ENGINE IS OPERATING, DO NOT STAND IN A
DIRECT LINE WITH THE FAN. DO NOT PUT YOUR HANDS NEAR THE
PULLEYS, BELTS OR FAN. DO NOT WEAR LOOSE CLOTHING.
Is the governor pressure on the DRB 276 - 379 KPa (40 - 55 PSI)?
All
Yes ® Go To 29
No ® Go To 30
439
TRANSMISSION
Continued
29 Turn the ignition off.
Replace the Governor Pressure Solenoid in accordance with the Service Information.
With the DRBIIIt, monitor the target governor pressure and actual governor
pressure.
Drive the vehicle at a constant speed 40 - 48 kmh (25 - 30 MPH).
Note: The actual governor pressure should be within 34 KPa (5 PSI) of the
target governor pressure with in 3 seconds.
Is the actual governor pressure within 34 KPa (5 PSI) of the target governor
pressure?
All
Yes ® Test Complete.
No ® Repair the internal transmission leakage problem in accordance
30 Turn the ignition off.
Start the engine.
Read the governor pressure on the gauge.
Is the governor pressure on the gauge 276 - 379 KPa (40 - 55 PSI)?
All
No ® Go To 31
31 Turn the ignition off.
Remove the transmission oil pan and inspect for burnt oil and excessive debris.
Is the transmission oil burnt or does the transmission oil pan contain excessive
debris?
All
Yes ® Repair the transmission in accordance with the Service Information.
No ® Go To 32
440
TRANSMISSION
Continued
32 Turn the ignition off.
Start the engine.
All
No ® Replace the valve body in accordance with the Service Information.
33 At this time, the conditions required to set the DTC are not present.
Note: Use the Freeze Frame Data to help duplicate the conditions that set
the DTC. Pay particular attention to the DTC set conditions, such as, VSS,
MAP, ECT, and Load.
Note: Visually inspect the related wiring harness. Look for any chafed,
pierced, pinched, or partially broken wires.
Note: Visually inspect the related wiring harness connectors. Look for
broken, bent, pushed out, or corroded terminals.
Note: Refer to any technical service bulletins that may apply.
Were any problems found?
All
Yes ® Repair as necessary.
No ® Test Complete.
Start the engine.
All
Yes ® Go To 29
No ® Go To 30
439
TRANSMISSION
Continued
pressure.
pressure?
All
Start the engine.
All
No ® Go To 31
debris?
All
No ® Go To 32
440
TRANSMISSION
Continued
Start the engine.
All
MAP, ECT, and Load.
All
No ® Test Complete.
charger7022
01-01-2008 03:25 PM
O.T
09-06-2007 06:10 PM
CTD NUT
04-05-2005 04:45 PM
