Big Rigs Talk about other Cummins powered vehicles here. As a matter of fact, it doesn't even have to be Cummins, but it will be diesel! :)
Detroit Diesel 50 PWM
Old 09-02-2014 | 07:36 PM
moosemanusa's Avatar
Unhappy Detroit Diesel 50 PWM
Howdy All,
First post for me (YAY)
Does anyone know where the PWM valve is on a D50 motor! I've looked everywhere! I'm Stumped!
Its throwing Flash Code 63 which means short on the + Side however I cannot find it, I've spent hours researching, even trying to buy one so i can compare but no luck..
Thanks, Moose
Old 09-04-2014 | 12:17 AM
2006BLKMegacab's Avatar
Welcome to the DTR, from what I can decipher (I'm not a Detroit guy so I may not be much help) the PWM valve I tied into the turbo setup to control the VGT nozzles (but that may be the 60 series setup too)
I found the 8 page troubleshooting guide seen here: http://www.ddcsn.com/cps/rde/xbcr/dd...SECM-03-83.pdf
hope it helps or someone smrter than me can actually help haha
Old 09-05-2014 | 10:20 PM
bjytech's Avatar
Flash code 63 means that one of the PWM(Pulse Width Modulation) output wires from the ECM is either shorted to positive or a open circuit. I'm not familiar with the 50 series but here is a excerpt from a troubleshooting manual on flash code 63
http://dmbruss.com/images/Schematics..._PWM_Fault.pdf
Old 12-30-2014 | 06:04 PM
I Forgot I even posted up here, Thanks to Everyone..
The problem is these engines have many applications.
So far I've found the following
1 - PWM can be used to control a fan (Not in my case) - Fan is on the crank.
2 - PWM can be part of the Glow Plug System (Not in my case) - No Glow plug system, Uses Ether to start and pure compression.
3 - PWM is part of the EGR system (I dont have that either).
This motor has the Detroit Ether start unit, I've ordered a new can just incase its a flag triggered by an empty ether can (Standard install on this application).
I've read the DDR and D50 manuals, I cannot obtain the specific manual for the application as its on a bus and cities either throw the manuals away or staff take them and leave in their attic for ever
sheriffav8r
05-23-2008 07:38 AM
spitzair
01-12-2005 08:52 PM
bkrukow
11-29-2004 09:17 PM
BIGHEAD
07-28-2004 10:58 PM
DieselDaze
04-28-2004 02:35 PM
