pistons coating ?
Old 03-02-2010 | 12:13 AM
winkdemon's Avatar
pistons coating ?
were can i get a set of pistons in alberta ? any one now
Old 03-02-2010 | 02:34 AM
Tate's Avatar
12v? I think you can get coated marines from Cummins.
Old 03-02-2010 | 09:45 AM
Mike Holmen's Avatar
The Guru
They are going to be pricey, here in Alberta. Anybody know what kinda of coatings that they use on the pistons? Keep us posted on what you find buddy.
A Piston from Cummins and coated, wow, I wonder what thats worth.
Old 03-02-2010 | 11:05 AM
winkdemon's Avatar
well i wil phone my engine builder buddy in ontario see what he says
Old 03-02-2010 | 11:15 AM
ccmckee's Avatar
Regular pistons are $400 ea from cummins, i can just imagine what coated ones would be.
Old 03-02-2010 | 11:18 AM
John_P's Avatar
winkdemon:
Let me see if I can give you some info here.
Cummins does make a piston that is coated but I am pretty sure it is a marine piston. You can also send your pistons out to have the coating done.
Scheid Diesel has done my stock pistons before or they can order you coated pistons from Arias or Mahle. The coatings vary, but they are generally a high heat ceramic coating and IMO they hold up very well and do make the pistons last longer. You can contact Brad Ingram @ Scheid Diesel if you are interested. Here is his toll free number: 1-800-669-1934.
Hope this helps you some Sir.
John_P
Old 03-02-2010 | 11:28 AM
winkdemon's Avatar
great
thanks for the info
Old 03-02-2010 | 12:34 PM
John_P's Avatar
Originally Posted by winkdemon
great
thanks for the info
winkdemon:
You are very welcome Sir.
One other thing I would add is the price that DTR Member ccmckee gave you on the price of Cummins pistons is close, but if you shop aroung on-line you can find some better prices than that.
John_P
Old 03-02-2010 | 01:02 PM
The Guru
Rob, is it for a 12v, 24v or a common rail? I can probably find you 6 pistons for the same price as cummins parts would sell you two.
John P, How did they coat the piston? The top, bowl, skirt, inside?
Old 03-02-2010 | 03:14 PM
John_P's Avatar
Mike:
On the stock set of Cummins Pistons that Scheid Diesel had coated for me they coated the sides of the piston and down the skirt. Not inside though.
The Arias and Mahle Pistons are entirely coated, but they are forged pistons, not cast.
Hope that helps you some.
John_P
Old 03-02-2010 | 05:32 PM
The Guru
Thanks buddy, I'm just trying to figure out this stuff myself.
Old 03-02-2010 | 05:57 PM
krh's Avatar
krh
alberta engine sells federal mogul pistons for a **** good price. If you have to resort to buying pistons and getting them coated
Old 03-02-2010 | 08:33 PM
Tate's Avatar
Talk to Snedge on comp-d. He is a Cummins partsman and supposedly has unbeatable prices.
Old 03-03-2010 | 01:57 AM
winkdemon's Avatar
well when i put my 12v back together i was thinking of coating the pistons ,, the but it depends on price , i no it does make a differents i had a set in a gas engine night and day differents
Old 03-03-2010 | 04:26 PM
John_P's Avatar
winkdemon:
I agree with you on the coating not only making a difference on the heat, but with the ones I had I also saw less wear on the sides of the pistons too.
RollinCoalSmoke
05-29-2009 10:20 PM
skynyrd
01-10-2008 07:41 AM
Lurch519
17
06-27-2005 02:41 AM
AlpineRAM
05-27-2005 11:00 PM
ddestruel
05-10-2005 01:17 AM
