Local calgary small gas engine shops?
Old 01-30-2011, 09:26 PM
1-5-3-6-2-4's Avatar
I need a carb rebuilt for a 5hp tecumsa. anyone know a place in calgary?
Old 01-30-2011, 09:44 PM
pind's Avatar
Luke, I'd say your workbench at home. Those little carbs are dead simple to work on.
In fact, if you understand carbs at all, they're all easy to work on. Even holley... and I don't like those.
You should be able to find a rebuild kit for it, and just pop it apart in about an hour or so.
Old 01-30-2011, 10:19 PM
yes true/. I've had it apart already here. I need the rebuild kit though. I have no idea where to get parts for an old tecumseh. thats more what I'm asking
Old 01-30-2011, 10:36 PM
pind's Avatar
ALBERTA FOREST & GARDEN 1220 MERIDIAN RD NE CALGARY T2A 2 (403) 248-0878
Might try those guys, they are listed as a full line tecumseh dealer.
otherwise
these guys have a pretty decent site http://www.outdoordistributors.com/tecumseh/tmain.html
and so do these guys
http://www.jackssmallengines.com/tec...arts_index.cfm
I have also had really good luck with the Lawnmower Hospital in Edmonton. Been dealing with them for years.
Old 01-30-2011, 11:00 PM
roxxx's Avatar
Busy but have had luck with them in the Past
I was Just thinking of packin up the Ariens for a service, that's were I Would take it. Or there is a place down by Blackfoot were we moved your cab Cant remember the Name of it same area though
Old 01-31-2011, 12:50 AM
Oh ya theres a place right next to Jays shop. I don't know what they carry but its **** close I'll check them out.
Old 02-01-2011, 09:46 AM
Homestead's Avatar
Rick at Mechanical Services in Cochrane is awesome. He will get you anything you need and then some. 403-932-3802
I've been dealing with him for years for all my small engine stuff.
Jeff
Old 02-01-2011, 10:39 AM
dvst8r's Avatar
Two Brothers Small Engines, right here in the foothills industrial park.
Old 02-02-2011, 05:03 PM
winkdemon's Avatar
action engine and i can build it
Old 02-02-2011, 05:27 PM
Tedonlin150's Avatar
I'd be surprised if they rebulit it for you. Most places replace with an aftermarket carb which ends up being cheaper than rebuilding.
Old 02-02-2011, 07:30 PM
I would rebuild it. if I could. I've had it apart. is fubar. like FUBAR inside. so I'll have to order a replacement. for the hundred and change that it'll be. its not worth the hassle of trying to clean it, with a kit. and it still not working right.
Old 02-02-2011, 07:42 PM
See if you can look up an aftermarket one from Oregon
Old 02-02-2011, 07:50 PM
what do you mean an aftermarket one from Oregon? is the company called oregon?
Old 02-02-2011, 09:49 PM
Oh I see yes. looks like this is it. $70 not bad. I mean really the rebuild kit here and new float and small parts is easy 1/2 that to start with.
http://www.cmsmallengines.net/oregon...h-632334a.html
Old 02-02-2011, 10:44 PM
Yep. Buying a rebuild kit and doing it yourself is definately cheaper. It is a lot easier to just slap a new one on though and theres no adjusting.
Quick Reply: Local calgary small gas engine shops?
