heater cores
Old 06-14-2009 | 09:15 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
heater cores
Whats this with heater core pipes that rotate??I got one from Napa and the ends rotate...Is this safe???
Old 06-14-2009 | 11:39 PM
Doj Dewd's Avatar
i'm sure they are fine . . . or else they wouldn't sell them.
on the other hand, the replacement i picked up from auto value was all solid. it was a spectra heater core.
if i had a choice for the same price, i would choose the solid one. (hopefully we don't make you go back and get a different one!!!)
Old 06-15-2009 | 12:07 AM
torquefan's Avatar
On the older trucks that use a cable to control the blend door, after you install an aftermarket heater core make sure the blend door linkage will do a full sweep from hot to cold without hitting the heater core's pipes. I've found some of the aftermarket ones are shaped different from the OEM ones and will obstruct the travel of the linkage.
totalloser
09-05-2012 12:37 PM
Varmint
02-01-2010 10:39 PM
Doj Dewd
ABDTR #5
45
01-14-2009 07:53 PM
redramrider
12-26-2004 07:56 AM
South Bend Clutch
10-25-2002 01:11 PM
