Drivers side 2 gen window and lock switch assembly
Old 07-19-2010 | 06:30 PM
Scotty's Avatar
Top's Younger Twin
Anyone got one laying around or know where I might find one. So far the two from the wrecker were duds in different ways then the original.
Its from an 00".
Scotty
Old 07-19-2010 | 06:42 PM
Totallyrad's Avatar
Are you absolutely sure it's not the wires in the door jamb?
Old 07-19-2010 | 06:51 PM
Scotty's Avatar
Top's Younger Twin
well, no. LOL When he hit the door lock the window moved down. When he hit the down mode on the drivers, it did nothing so he held the lock button in unlock and the window went up. I just watched as he did this and I also told him about the broken wires in my truck's drivers rear door.
He is checking the wiring right now but the switch is also loose on the driver window button...about to fall out. He may have two problems...switch and the wires.
Old 07-19-2010 | 06:54 PM
Totallyrad's Avatar
Roger that, could be two problems but it sounds like the switch is toast anyway.
Old 07-19-2010 | 07:00 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Scott...Did you check if there where any 1/4 ton Dodge Dakota in the junk yard for the lock switch...I'm not sure if in 00 they changed the lock switch.I needed a lock switch for my 95 and found the Dakota had the same switch
Old 07-19-2010 | 09:50 PM
Scotty's Avatar
Top's Younger Twin
I will check. Thanks
Old 07-20-2010 | 11:22 AM
Lil Dog's Avatar
Its rare that the switch would be bad. They are easily taken apart and polished up to work. With the way things are going I suspect wiring.
Old 07-20-2010 | 04:16 PM
Tate's Avatar
Jason (doj dewd) had some funky problems with his power locks/windows. Traced it back to the key lock. It has the kind of lock where you turn it twice and it unlocks both doors. After it got broken into and then 'repaired' by the dealership, he had windows that would lock the doors. Ended up unhooking the wiring from the key lock it went back to normal.
Old 07-20-2010 | 04:27 PM
Mike Holmen's Avatar
The Guru
I fixed my 2002 today. As of today both my windows up/down and my power locks work. Both doors need door/window switchs and they need to be plugged in to work. I still have one bad speaker, so its all coming apart soon again, for the 100th time
Old 07-20-2010 | 09:47 PM
Lil Dog's Avatar
I've pulled my switches apart, are the newer models that different? I pulled the switch open on my 02 Town and Country and the same brass points and copper flippers inside.
gcliburn
01-24-2012 07:24 AM
WUnderwood
08-07-2010 10:28 PM
JBOND
01-31-2008 02:31 PM
chevyryan6
09-07-2005 09:01 PM
Lightman
18
11-19-2003 06:15 PM
