best place to buy 4inch exhaust ..cheap...
it went both directions, even put a hole in the torque tube on the intake... it has some serious carnage,, one of these days I am going to take some pics and post them... it is a mess for sure.. I am going to pull the intercooler off this week and see if there is any damage in ther too
I'v been told you can weld stanless with a regular mig useing wire ment for steel, but it will rust cus its regular steel in the weld and prbably not as strong as using the proper wire for stainless.
I would try the afe exhuast its pretty cheap, cost around the same as mbrp aluminized but its stainless. IT'll still rust, but i think it'll take longer to rust a hole though than the aluminized. NADP was selling it, probably still are. I've done a few they fit pretty good, not as good as MBRP though
Does it look something like this?
i fished that turbine wheel out fron the base of the stack, after it when through the resonator/ and down the s-pipe down tube.
AND.........the compressor wheel spun just fine on the other side of this. didn't damage the blades at all.........
just a turbo failure under load. yup its a big garrett. actually the fish mouths go all the way down looked just like a candy striper pole red & white round & round.
The Guru
How did it break? Compressor surge and/or overspeed? I can't see the pictures but thats what usually kill things. How dirty is the filter? Another turbo killer.
The Guru
Luke, you have anymore pics? Are the turbine blade tips scored? How heavy? That shaft looks nasty badly twisted piece, I wonder if the compressor was surge and turbine blades were smashed turbine housing going at around 100k cpm. Any compressor pics?
5.9Excursion
11-21-2007 06:50 PM
tywebb3
12-30-2006 09:39 PM
Lambo
05-25-2004 06:27 PM
Chris_O
30
09-19-2003 06:51 AM
