Mega Cab Gooseneck Hitch
Old 09-19-2012 | 08:57 PM
MOverton's Avatar
I am wanting to trade my 03 quad cab for a 4th gen mega cab. I currently have a diesel tank in the bed of my 03. I will need to put the tank in the mega cab. The tank is 31 inches wide. Will I be able to have the tank and still have a gooseneck hitch? Any help would be appreciated.
Old 09-20-2012 | 01:07 PM
SOhappy's Avatar
Dumb question on my part but have you taken a good look at the crew cabs? Much improved over the old quad, same leg room as the Mega, but you can get one in a long bed. All that would be lacking is the reclining rear seats and the space behind them. I believe they are slightly less $$ as well.
Old 09-20-2012 | 08:18 PM
MOverton's Avatar
Not a dumb question at all. The reason for a mega cab is I have found one that has a salvage title, resulting from it being stolen. The price is more in my price range and gives enough room for my son.
Old 09-21-2012 | 07:56 PM
Blake Clark's Avatar
Dont think you will be able to. My lil bro was going through the same dilemma with is 07, and I know he took a bunch of measurements. I see if he can remember what they were.
Old 09-24-2012 | 01:41 PM
SOhappy's Avatar
Wonder if a flat-bed conversion would make it possible?
Old 09-24-2012 | 06:13 PM
kerry.king's Avatar
I had a huge 80gal transfer tank in the bed of my 08 mega. no fitment problems at all. I slid it across from the bed of my '01 in the dealer lot by myself. had to lift it over the fender wells in the '01, but it slid between the wells in my '08. Only draw back is you're screwed for bed space after putting in the tank.
Old 09-24-2012 | 07:55 PM
Slade Clark's Avatar
'Little Blake'
OK, first is it 31 inches wide? or 31 inches deep?
The major issue is the fender wells, I believe (Been awhile since measurements have been taken) you only have around 2X (maybe 28") of bed before the fender wells. Which is the issue.
MOST L-Shaped tanks WILL FIT but they go to far into the bed for the goose-neck. So if you want goose-neck, scratch those.
Pretty much anything that's 45gal+ will be to large for the application you are trying for. The only option I have seen was my brother's setup with a 45gal tank that sat far enough up to clear for a goose-neck.
Other then that you always have the option to build a custom tank.
Old 09-24-2012 | 07:58 PM
Slade what size was that L tank you had in your truck. I know it came about 6" too far into the bed for a gooseneck setup. We would have had to notch the tank to make it work.
Old 09-24-2012 | 08:02 PM
'Little Blake'
That is correct. I had a 80gal L-Tank. It was closer to 3" to far into the bed. Which would have resulted in tank modification to work.
It was actually cheaper to have a custom tank built then actually try and modify the L-tank. Which took more skill then I possessed at the time.
Old 09-24-2012 | 08:04 PM
Originally Posted by Slade Clark
It was actually cheaper to have a custom tank built then actually try and modify the L-tank. Which takes more skill then I possess at any time.
Ok.
BTW, I fixed that for ya.....
Old 09-24-2012 | 08:09 PM
'Little Blake'
Ok.
Remember I have a Fifty....
Old 09-26-2012 | 09:24 PM
MOverton's Avatar
The tank is 31 inches deep. It will fit between the fenders of my 03.
Old 09-27-2012 | 10:47 AM
Busboy's Avatar
I measured my crew cab short box with my B&W hitch its 29 inches from the front of the box to the front of the pin it's also 17 1/2 inches from the front of the box to the start of the wheel well starting to rise. You should be able to compare the Crew cab and the mega cab measurements and transpose the 29 inches. To gain extra depth for a tool box I notched the box and raised it 2 inches, this enabled me to use the B&W companion.
Yeti41
ABDTR #5
12-01-2010 10:15 PM
440727
05-14-2010 05:06 PM
jimbo486
13
11-05-2009 09:17 AM
sodikart
03-15-2006 08:51 AM
jlasich
03-31-2004 11:08 PM
Quick Reply: Mega Cab Gooseneck Hitch
