lug studs broke...
lug studs broke...
I am wondering if anyone else has had this problem.....all left rear lug studs broke pulling a trailer down interstate 75.. Really wondering what would cause this.....
Cummins Guru
Over or under tightening lug nuts, aftermarket wheels or rims, overloading trailer, using anti-seize on threads, bent rim or extremely out of balance wheel. accident damage, bent axle, I would start with those for possible reasons.
By the way you need to enter your vehicle info.
they broke on the rear of my 2012 ram 3500......the truck had 210,000 miles on it .....just put new tires on the rear a month ago.....has anyone else had this problem...I got a 2014 ram 3500....hope it doesn't happen to me again...pretty scary..
Here is my story, a little different but...
https://www.dieseltruckresource.com/...d.php?t=305238
Depends on what rims you have. My dually ran alcoa rims. The rims come with a flush nut/washer set up, not an acorn/tapered nut. Having a flush nut makes it real hard to center/balance the tire and if you run bigger rubber that only magnifies the problem, thus creating more stress on the lugs.
Hope you find the answer to your problem...crazy scary losing those.
lug studs
the truck was....notice I said was a 2012 3500.....an it had 210000 miles on it.....loved the truck....I go all over the U.S......just replaced it with a 2014 3500 ram of course...just wanted to know if anyone else has had this problem....I know they had the recall on the front tie rod...I hope this isn't another problem...
My issue was due to aftermarket parts. Most broken studs are due to improper tire/rim mounting (over/under torqued lugs). Which is only magnified being under load (pulling a trailer). There is not much I have read in any forums about your situation...so I would assume it was a one off, but broken lugs do happen.
lug nutts
appreciate all the input on this....just making sure its not another recall....thanks again.....my new ram 2014 3500 is doing great ive had it 4 weeks already rolled up 3600miles.....gotta pay the bills someway
Trebor
09-14-2006 04:52 PM
LongRanger
08-31-2006 09:28 AM
DrBob
09-06-2005 07:39 PM
