Anybody know what this part is called? URGENT!
Long story short, I hit a deer on the way home tonight and the big bumper took most of the hit (and handled it perfectly) but I need to replace my A/C condenser radiator and the part behind the headlight that holds it in. I need to have it all fixed up by the weekend when I have to head back up north to work. I have been through as many parts manuals and service papers I can find but I can't seem to find what that part is called. Its the large plastic wing portion that bolts to the main rad support and has the plastic slider lock tab that grabs the headlight just above the wheel. It wraps around the back and bottom of the headlight and is pretty much the only thing back there where all the headlight tabs snap into. Even if somebody has a drawing of that area I could point out the part. Thanks in advance.
It's part of the bumper bracket I believe, not sure if this part number is the right or left side but it will get you close enough your dealer should be able to do the rest. Part # 68064329AB.
Should be the left side part number. Generally, Dodge part numbers have an odd number for left side and even number for the right side (referring to the last numeric digit on the part number, in this case a 9.)
That looks like the fog light bracket from the stock bumper. I'm in need of the part that the actual headlight pops into with the white sliding lock tab. Dealer looked it up today and they only list the entire rad support for WAY over a thousand dollars. Looking at the truck the headlight support clearly bolts to the main structure of the rad support.
sallyman1
03-21-2008 12:28 PM
cheapskate
13
01-26-2007 08:12 AM
