Help; looking for part numbers
Howdy! I am adding seat heaters to my truck and want to utilize a factory switch and not be boring holes in the dash. I am looking for the part number for the factory seat heater switch with the exhaust brake, light load and emergency flasher switch. I am also looking to install and overhead console (for extra light) and looking for the part number for just the overhead console with the lights....and maybe the compass....
Thanks
Thanks
You posted in the 4th Gen section, but your sig says you have a 2000. Possible misprint and it should read 2010?
If so you can try www.mopar.com and use the e-store. It only goes back to 2001 though so you may need to visit the dealer and/or post in the 1st & 2nd Gen section - if your sig is correct.
Another option is to check this site - helped me a few times when researching parts:
http://www.jimsautoparts.com/mopar_p...m_interior.htm
Oh! I forgot to mention, when I was researching the parts to swap in the center jump seat, it was really helpful to figure out what the 3 digit codes were. I pulled out my build sheet and that helped me out a lot.
I found a truck for sell online that had exactly what I wanted on the interior and used that VIN # to pull the correct parts through the mopar site and gave it to the dealer I ordered from online to cross-reference.
Good luck on finding it though!
nvr-enuf
07-15-2013 01:14 PM
crossy
07-18-2006 05:18 PM
MR. GADGET
05-01-2003 11:24 PM
