H & S Tuner Purchase
sad thing is that EPA does not care 1 red cent about how much fuel is being used.
Here is something that adds to my confusion....
If i do just the DPF, EGR delete vs the CAT, DPF and EGR delete, the cost difference is only $50....
How much more involved is the CAT delete... do I need to drop the tranny? T-case? or just the Crossmember?
I don't need 8 hrs worth of work to drive five miles for a 15 minute inspection....
Any suggestions on this?
Thanks
Thanks
A new LOW
Just wanted to share....
Last night I topped off my tank.
I had driven about 210 miles. I topped off with 17.716 gallons
11.8 mpg..... this was with city driving... the Lie-O-Meter said i had gotten 12.8 average....
Cant wait to order the deletes...
my truck goes into the dealer ship next week to get a new power steering pump and u-joints.... after that ....I plan on ordering the parts.
Thats what my truck got too, NOW 16/17 and 19/20 hwy
Thanks
Thanks
Does this become a two man job?
with the difference in mileage gains between the two....is the full delete worth it?
you already have 4" exhaust so no need to go to anything bigger plus the factory muffler is a "see thru" muffler. get the down pipe which will delete the cat in the down pipe, and get the delete pipe which will delete the DPF and 2nd cat along with the sensors. keep the sensors in tact within the factory exhaust and store the parts in the garage. put all of your nuts, bolts, clamps ect in a gallon zip lock and in a box for futur use if the need ever arise. will have to drain the coolant to do the EGR system. The EGR cooler is known to leak, that is the primary reason (other than wanting it out of the engine bay to clean things up) that I got rid of mine.
You just need a chuck of 4in exhaust. Weld a 4 hole flange onto the end. The turbo down pipe, first cat can stay on. Basically you just need to remove the cat and dpf. 10-15 minutes of work. Mine just fell onto the ground with no issues. Took me 15-30 minutes to make my own delete pipe. To go back to stock its about 30 minutes of reinstalling the cat/dpf and hook-up the exhaust sensors. Takes about 15 minutes to get the computer to stock.
Removing the egr/egr cooler and turbo down pipe is optional. If you going to just use plates, I would just buy an air horn and find a 2nd gen manifold. There adapters to convert T3 to a T3I flange, or just drill the turbine housing for the T3 bolt pattern.
Where to Mount
Since I have decided to pull the trigger, I have been looking at places to install the H&S Minimax in the cab.
I have the bench seat in the truck so on the consol is out of the question.
Could someone post a pic for give some ideas?
Also, what type of mileage are you seeing with leaving the upper CAT installed?
