H&S Mini Max
H&S Mini Max
Has anyone had their mini max or other programmer jump power settings all by itself? The buttons to change power setting do nothing when this happens and the head has to be unplugged to go back to mild. H&S is closed today.
I spoke with H&S (their support is terrific) They need access to the truck to troubleshoot. I must clarify the truck only jumps UP in power, it's NOT defueling. Because of time constraints we didn't get the egt probe installed so it is an issue if the truck gets stuck in deep snow we can't protect the engine using EGT. H&S did suggest using boost pressure to defuel to lower power settings and we will do that until we can get to troubleshooting it. With the mini max there is no "after market" ground needed you only supply +12V it gets everything else it needs from the OBD2 port except EGT.
I will update what is found but it could be awhile. Going by how much better this truck is running and fuel economy I can't wait to get the other truck deleted.
Just to update.. we have discovered that the mini max sometimes jumps up in power settings when the VHF COM radio is used to transmit. It doesn't do it all the time but that is what is causing it to jump up settings. I spoke with H&S tech and they spoke with their engineers. They feel it's not a power fluctuation but RF interference and there is nothing they can do. We plan to move either the Mini Max head or the VHF COM itself as the two are about 8 inches apart.
shlen
12-21-2014 12:22 AM
95black2615
07-17-2012 01:15 PM
pett359
12-24-2010 02:47 PM
West Coast
03-03-2009 09:25 PM
