flo pro exhaust
Old 11-17-2011 | 11:46 PM
6speedcowboy's Avatar
flo pro exhaust
Trying to decide on an exhaust for my truck. Not sure if I should get the 4 or 5 inch and if I want to run a muffler or not. How is the fit on their systems and what kind of sound level differences are there between the different sizes with and without muffler. Looking for a good throaty sound but nothing loud and obnoxious
Old 11-18-2011 | 12:24 AM
Jordan5687's Avatar
I'm also curious about this, I just purchased a flo pro muffler and deleted for my 11. Guess ill find out in a few days. I don't want drone from the exhaust.
Old 11-18-2011 | 12:51 AM
Riverbound's Avatar
My 07 is straight piped with a cat and I want to muffle it. I have a friend who has the same truck with a performance 4 inch and a muffler. And its much nicer especially on the high way.
Sent from my Droid using Tapatalk
Old 11-18-2011 | 03:58 AM
Blake Clark's Avatar
I have a straight 5"
Its not nearly as loud as I would have thought. Has a nice deep tone to it and a touch of drone at 2200rpms. Nothing I cannot deal with.
Now I havent towed anything with it yet either, so cant say on that front.
Old 11-18-2011 | 05:26 AM
New2Diesel's Avatar
"Gomer Pyle"
I 2nd the 5" no muffler. My truck sounds amazing and not too loud.
Old 11-18-2011 | 08:01 AM
How is the fit on the 5" system? Do you have to relocate the spare tire with it?
Old 11-18-2011 | 08:16 AM
cbrahs's Avatar
no relocation of anything. I have the 5" with muffler stainless turbo back flo pro system. I don't use their clamps though but the OCD kicks in and I buy Donaldson 5" preformed stainless clamps off of a semi. can get them at any big rig dealer for about $12 or so each. Use an impact to get them on as you WON'T get them tight enough by hand. the fit and finish of flo pro kits are great. only beef I have with them (or with any exhaust kit that large) is that sometimes I have received the kits that the ends are bent but nothing that can't be straightened out with a pair of channel locks. I think its from fed ex or ups driver being ticked cause the box is so heavy and dropping an edge on the ground and causing the damage.
Old 11-18-2011 | 09:42 AM
New2Diesel's Avatar
"Gomer Pyle"
To add to what cbrahs stated, since I have the Mega Cab I had to cut about 8" off of the extension pipe that they sent to me because it was too long.
Good thing is that I have a great welder and once cut I welded everything in. No clamps except for at the turbine and the one all the way in the back. Trust me, it was not easy.
Old 11-18-2011 | 10:11 AM
Good deal. Think ill go with the 5 inch since it will fit with the spare tire
Old 11-18-2011 | 11:27 AM
How much clearance is there between the spare tire and the spring with the 5" system?
Old 11-18-2011 | 11:33 AM
cbrahs's Avatar
plenty
Old 11-18-2011 | 11:49 AM
Thanks guys!
Old 11-18-2011 | 12:27 PM
cbrahs's Avatar
here is a pic of mine laid out before the install. I have installed a bunch of these and thank God it happened on my truck but I was getting a bad vibration that would transmit thru the cab only at idle. i checked clamps, any place possibly touching metal, ensured rubber mounts were secure but found out the muffler was the cause. spoke with flo pro engineer about it too. so I deleted the muffler and it went away (for the most part). reinstalled the muffler but installed it in the farthest place rearward and vibration is gone.
https://www.dieseltruckresource.com/...ghlight=delete
you can see the section of straight behind the muffler, swap that piece and put in front of the muffler.
Old 11-18-2011 | 01:21 PM
Thanks! Ordered the 5" straight system, black maxx, and egr/cooler delete. I've had the truck for 3 weeks and can't wait to get it running right
Old 11-18-2011 | 04:15 PM
On mine everything clears pretty good. Firewall, spare no issues. The rear shock is a little close, but didnt have any problems with it.
Quick Reply: flo pro exhaust
