4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Big time scare, thought trans case failed
Old 09-28-2011 | 03:56 PM
ranchertx's Avatar
I was loaded with 15,000 lbs of cattle and trailer, and engaged 4WD low to Get up the hill at the ranch. When I crested the hill, I stopped and went to 4WD high. I started out and got the load rolling then switched to 2WD high, and I heard a loud pop and the truck stopped responding to the throttle.
I messed with the electronic 4WD shift **** but could not get it into Gear, it was like is was in neutral. I even tried restarting the truck, hoping maybe the electronic shift would reset. My worry was something had broken in the transfer case.
The I noticed that it appeared the light under the "neutral" button was lit, and I pushed it several times but no luck, would not go into gear.
I read the manual, and no help.
Finally I held the button and after 3-4 seconds it went out and I was back in gear! Just a big FYI, if this happens and it is really bright daylight, the Neutral switch lite is hard to see, and to reset it, you must HOLD THE BUTTON DOWN for a while!
Evidently I had hit the neutral button when I switched over from 4WD to 2 WD. Lucky for me I have not already called a wrecker when I figured out what had happened.
Old 09-28-2011 | 03:59 PM
Blake Clark's Avatar
To be honest.
I love my Laramie and everything in it. Just why, Dodge, why, cant you put a dang manual shift on the transfer case??
Hmmm?
Is that too much to ask?
Old 09-28-2011 | 06:11 PM
jstone44720's Avatar
Blake,
Did they stop offering that package? There was a package that started with a J that was basically Laramie minus the evil electric transfer case switch. Is it no more?
Old 09-28-2011 | 06:15 PM
Originally Posted by jstone44720
Blake,
Only truck you can now get the manual shift xfer case on is the ST package.
Old 09-29-2011 | 09:34 AM
ranchertx's Avatar
They picked a bad location for the Neutral button, and, need a yellow light in lieu of the dim red one. If there is direct light on the button you cannot tell it is illuminated.
Old 09-29-2011 | 01:52 PM
ctnv's Avatar
I want manual lockers on my 4x4 to increase mpg and decrease ware. I use 4x4 rarely but must have when needed. Why don't the big three offer this as an option especially considering the price of diesel.
Old 09-29-2011 | 02:25 PM
ranchertx's Avatar
I know Ford was still offering manual hubs for a while. I am sure it is all about demand, most poeple that get 4WD's don't ever use it and prefer the electronic controls. It has been a while since Dodge even offered manual hubs, maybe 15 + years?
TheNeckasaurus
12-12-2011 10:08 AM
PeteRR
03-13-2007 04:21 PM
mogpuller
02-06-2007 05:12 PM
Ramdriver15
06-29-2006 07:03 PM
Dodgezilla
32
01-18-2006 11:09 AM
Quick Reply: Big time scare, thought trans case failed
