4'' down pipe
Old 02-04-2008 | 02:43 PM
red_neck1984's Avatar
4'' down pipe
So i called Stans Headers and asked them for a price on just a 4'' down pipe to the t-case and it was almost $430 and the hole package was $495.So my question is are Stans exhaust and the Donaldson truck muffler any good for the price or should i just build my own down pipe and mess around with all the BS and welding?or buy from others ?Also I put a 14cm2 N/WG turbo on so it has moved the down pipe back a 1.5in and he say the Stans on will bolt right on no worrys.
Old 02-04-2008 | 05:11 PM
97catintenn's Avatar
I'm wondering the same thing. Hopefully someone can clear this up for the both of us. It sounds expensive.
Old 02-04-2008 | 05:20 PM
Proram's Avatar
4" Dp
Why would you go to all that trouble when you can just use a 2nd gen 4" DP and the cast elbow and come out about 150$??
Scott
Old 02-04-2008 | 06:04 PM
CaptainChrysler's Avatar
Hopefully by this weekend I will have that!
Old 02-04-2008 | 06:22 PM
SuperiorRam's Avatar
stans works fine with the longer housing
Old 02-04-2008 | 06:38 PM
DanMan's Avatar
I've got my new Stan's system sitting at work still in the box waiting to be installed. I must say this is a NICE system! Very high quality. The muffler is a true straight-through one and has a bracket welded onto each end. Once I saw the muffler and quality of the down pipe I was convinced of my decision to purchase it. I bought it from shop in WA for $530 shipped.
Attached Thumbnails 4'' down pipe-0131081137.jpg   4'' down pipe-0131081138.jpg
Old 02-04-2008 | 07:17 PM
mhuppertz's Avatar
Scott
Which 2nd gen had a 4" elbow?
Old 02-04-2008 | 07:18 PM
SmokemS's Avatar
i believe the 24v 2nd gen
Old 02-04-2008 | 07:32 PM
He means the stock 94-98? elbow and a second gen 4" DP. Surely its better than the S-curve.
Old 02-04-2008 | 07:34 PM
CaledoniaOutlaw's Avatar
I also used a second gen down pipe and elbow a year ago when I did mine. I believe it was a 12v
Old 02-04-2008 | 08:14 PM
looks like an idea can you get some better part numbers ?ie down pip and elbow
Old 02-04-2008 | 08:23 PM
77machomopar's Avatar
i just got done biulindg my downpipe a couple minutes ago and it was an improvement in lowering my egts. it sounds better also. only took about 2 hrs to build. thats with stopping and BS'ing alot
Old 02-04-2008 | 11:25 PM
SmokemS's Avatar
77 wheres the pics?
Old 02-04-2008 | 11:53 PM
PICS
Old 02-05-2008 | 07:53 AM
Pics
Ill take pics tonight and post them. HOw do i go about posting them?
Quick Reply: 4'' down pipe
