For you early 03' guys
Hey guys. I have a few questions. I'm looking at a truck(again, sorry to bring this up again) and I need to find out some stuff because it is a good deal(I hope).
The truck in question can be found here . The salesman I called was very knowledgable about the truck as he drives it all the time cause they are having a hard time selling it in NJ. It has 88k on it and it is an early 03'. It has the 10.5" rear and I think a 47RE. The salesman couldn't find what engine it had (SO or HO) or the tranny specifics.
Next, it had fuel problems and they put what he says is a high pressure in line pump. After they did that it still had problems so they put an in tank model in it. Now it has two pumps in a series(good or bad?) He doesn't know what the in line pump is(it may be mopar). He also said it has SOME new injectors and told me it was related to the fuel problem. All repairs were done at his dealership.
He says he himself has put 15k on the truck and loves it. Gets 18-22mpg on the highway and hasn't been a tow rig or a work truck. Interrior looks great. Says it needs new tires (not important).
Is there anybody that could run the VIN 3D7KU26603G727942 for me? Also, how would I get a truck from NJ without test driving it?
Thanks.
Thanks.
Thanks.
Thanks.
If you are that interested in a truck the dealer hasn't been able to get rid of for the past 15k miles, maybe you should go see and test drive it.
Good Luck,
NEVER buy anything east of the Mississippi. Too much rust.
It does not need two fuel feed pumps, and neither one should be high pressure.
If your salesman was truly knowledgable, then he should have known that its an SO, indicated by the '6' in the 8th digit of the VIN. An HO has a 'C' for the 8th digit. If you are still serious about getting this truck, have the salesman send a digital photo of the trim label inside the glove box so you can be better informed about what this truck is.
Surely you can find something in Amarillo, Abilene, DFW or OKC. Perhaps even Hobbs or El Paso.
My thinking on why he can't get rid of it is because he uses it and nobody sees it, also it is in NJ and most people there would want a diesel truck. People down here have them all over the place, just not single cab.
There is no way I would fly to NJ just to see if a truck was worth it. He looked at the glove box sticker, I just diddn't have lots of time to talk. I know the pump shouldn't be high pressure that was him trying to sound smart.
What I meant when I said "knowledgeable" is that he knows what a diesel is and at least knows what work has been done to the truck. The only question he couldn't answer was whether or not it had a 47RE or 48RE. I knew it was a SO by the 10.5" rear. Most can't answer ANY of my questions. I'm going to have my guy in town look into it. I still don't want to have him go to NJ to get it and then it be a POS and me not want it. I would be angry if I went to NJ for a customer just to get stuck with a truck nobody wants.
Is rust that bad of a problem in NJ?
Thanks
Originally Posted by FMB
Interesting. KBB says 19.4 if it was in EXCELLENT condition but I think the question I have for you is WHY you would get a truck from NJ without test driving it?
Good Luck,
Good Luck,
Did a VIN check with dodge and got this email back.
Thank you for your recent email to DaimlerChrysler Motors Corporation.
According to our records, your vehicle was equipped from the factory
with the following:
*V9 - Cloth 40/20/40 Bench Seat
-DV - Dark Slate Gray
AHC - Trailer Tow Group
AHD - Heavy Duty Snow Plow Prep Group
APDA - Lower Two Tone Paint
A42P - 5.9l TD ENG(ETC)/4SPD A/T 47RE(DGP)
BAZS - 136 Amp Alternator
BCQP - 750 Amp Maintenance Free Battery
BRTS - Anti-Lock 4-Wheel Disc Brakes
CBEP - 40/20/40 Split Bench Seat
CGDS - Front Height Adjust Shoulder Belts
CGWS - Next Generation Front Air Bags**
CGZS - Passenger Air Bag On/Off Switch
CKES - Front Seat Area Carpet
CLAS - Front Floor Mats
CSPS - Passenger Assist Handle
CUSS - Overhead Console w/Trip Computer
CU3S - Behind the Seat Storage / Bin
CXDP - Trim Parts For Diesel Engine
DGBS - All 4-Speed Automatic Transmissions
DGP - 4-Spd. Automatic 47RE Transmission
DHAP - Lock-Up Torque Converter
DH1S - Man Shift-on-the-Fly Transfer Case
DJQS - 5,200# Front Axle
DMES - 3.73 Axle Ratio
DRWS - 10.50 Rear Axle
DSA - Anti-Spin Differential Rear Axle
ETC - 5.9L Cummins 24V Diesel Engine
GACS - Tinted Glass Windows
GFD - Rear Sliding Window
GNAS - Rear View Day/Night Mirror
GNMS - Passenger Side Sun Visor w/Mirror
GTSS - Power Heated Mirrors, Fold-Away
GVBC - All Vehicles W/Power Mirrors
GXM - Remote Keyless Entry
HAAS - Air Conditioning
HGBS - Dash Liner Insulation
HGFS - Floor Tunnel Insulation
I57S - Route 57 - CSX & NS, Ridgefield, NJ
JAYS - Instrument Cluster w/Tach
JCBS - 120 MPH Primary Speedometer
JHAS - Var Intermittent Windshield Wipers
JJAS - Cigar Lighter
JJBS - Dual Note Electric Horns
JJJS - 12V Auxiliary Power Outlet
JPBS - Power Locks
JPDS - Power Windows, Driver One-Touch
LBCS - Glove Box Lamp
LMAS - Halogen Headlamps
LNC - Clearance Lamps
LPES - Cargo Lamp
MBFS - Bright Rear Bumper
MCMS - Body Color Upper Fascia
MCTS - Bright Front Bumper
MDAS - Front License Plate Bracket
MFDS - Bright Grille
MHAS - Black Windshield Moldings
MTDS - SLT Badge
MURS - Dodge Badge
MUSS - 4X4 Badge
MWDS - Removable Tailgate w/Caliper Latches
MXCP - Front Bumper Sight Shields
NAA - Federal Emissions
NBLP - Delete EVAP Control System
NFVS - 35 Gallon Fuel Tank
NHBP - Auxiliary Transmission Oil Cooler
NHKP - Engine Block Heater
NHMS - Speed Control
NMCP - Heavy Duty Engine Cooling
NZCP - Current Generation Eng Controller
PDRA - Graphite Metallic Clear Coat
QS2A - Bright Silver Metallic Clear Coat
RAAC - All Radio Equipped Vehicles
RBKS - AM/FM Compact Disc Radio w/Chgr Ctrl
RCDS - 4 Speakers
RDDP - Fixed Long Mast Antenna
SBES - Power Steering
SCFS - 4-Spoke Steering Wheel
SFBS - Front Heavy Duty Shock Absorbers
SGBS - Rear Heavy Duty Shock Absorbers
SHAS - Front Stabilizer Bar
SUAS - Tilt Steering Column
TBBS - Full Size Spare Tire
TBMS - Tire Carrier Winch
TT5 - LT265/70R17E OWL On/Off Rd Tires
TZGP - BF Goodrich Brand Tires
WD3 - 17X8.0 Aluminum Machined Wheels
WF1S - 17" Steel Spare Wheel
WLZC - All Aluminum Wheels
WMJP - Center Hub
XBSS - Pickup Box
XEFP - Transfer Case Skid Plate Shield
XFHP - Hitch - Class IV Receiver
XFKP - 7 Pin Wiring Harness
XFUS - Trailer Tow w/4-Pin Connector Wiring
XME - Under Rail Box Bedliner
YAAS - Build To U S Market Specifications
YEP - Manuf Statement of Origin
YHBA - 8 Additional Gallons of Diesel Fuel
ZEKP - Spring - Left Front
ZGRP - Spring - Left Rear
ZTJP - Spring - Right Front
ZVRP - Spring - Right Rear
Z7CP - GVW Rating - 9000#
1AAS - U.S. Dealer Retail
132S - Zone 32-New York
2CG - Customer Preferred Package 2CG
2TGA - Customer Preferred Package 2TG
3VTA - Customer Preferred Discount
4KZP - 4X4 Tracking
5A6P - Waterbase Paint
5I4S - Four Wheel Drive (4WD)/(4X4)
5TV - BusinessLink Inventory
5TX - BusinessLink By-Pass
5ZFS - 8 FT. Cargo Box
5ZJS - Regular Cab
5ZMS - 2500 GVW
594S - Vehicle Order Tracking
6CA - Paint Order Code
6USS - Label - U.S. Specifications
631S - New Jersey State Code
931S - New Jersey State Code
Please note that this list does not include any additions or
modifications made to the vehicle after leaving the factory.
Also, we would like to verify that you are the current owner of this
vehicle. We have noticed that the name and address provided in your
email are different from the name and address in our customer database.
It is important to keep this database current so that we can keep you
up-to-date on recalls, customer satisfaction notifications, and other
important information. Please reply to the link below letting us know
that you are verifying ownership and would or would not like the
information to be updated in our system.
Thank you again for your email.
Sincerely,
Wayne
Senior Staff Representative
DaimlerChrysler Customer Assistance Center
Is this truck worth buying with all of the things like (some) new injectors and in tank pump and with 88k mi.?
with the following:
JPBS - Power Locks
LPES - Cargo Lamp
MTDS - SLT Badge
MURS - Dodge Badge
MUSS - 4X4 Badge
RCDS - 4 Speakers
WMJP - Center Hub
XBSS - Pickup Box
4KZP - 4X4 Tracking
5ZJS - Regular Cab
5ZMS - 2500 GVW
Sincerely,
Wayne
Nobody huh?
I just want to know if any of you would buy this truck after some injectors have been replaced. And it is a SO with a 10.5" rear and a 47RE.
ANYBODY????!!!!!?????
Nobody huh?
Fuel problems? Ehhhhh, no!
Me not test driving it? Ahhhhh, no again.
History of dealer putting 15k miles on it cause they can't dump it? Ummmm... what's the word????? No!
47RE tranny? I don't remember if that is the early one or the later one, the earlier one couldn't hold up to an HO, don't know about a SO.
Again, IMHO.
The truck is located in Newton at a used car lot. IMHO, if you can't or don't want to go look at the truck to see if its worth it, than don't buy it. I would continue looking into getting a truck that is closer to you so that you can go look at it for yourself and drive it for yourself. I believe that if you are going to spend any money on a vehicle, than you should should go look at it for yourself and than decide. If you want to arrange to have a shop look at the truck, there is a shop in Caldwell, about 30 minutes east of Newton, that is very reputable and would give you an honest opinion. The name of the shop is AutoWurks Diesel and their website is www.autowurks.com Ask for Mike or Chris. Good luck.
1 Post
nothing wrong with an SO motor i've got one it gets good mpg and as far as the tranny got it in are 98 if you dont tow a lot i believe they hold up well, if you tow a lot prepare to get it rebuilt been their done that. bought one truck off the internet flew up to Dallas test drove then drove it home put about 150k on it before i traded it in. get midlife to look at then decide
I have an early 03 and it has been a great truck.107k miles no major problems. I wonder when he said high pressure pump he was talking about the injection pump. With all that being said ,I would avoid that truck because of the problems not because it is an S.O. Maybe if I could put 2 or 3 hundred miles on it to try it out. It justs sounds "fishy".
If Newton was in my (lower) half of the state, I would go look at it for ya.
Since I am clear at the southern end, I can only suggest you ask one of the guys posting in the thread going on about a NJ/NY Meet & Greet. They are all pretty close by-
Funny I had to go to TX to buy all of my trucks
I agree there should not need to be 2 fuel pumps and shouldn't need to be high pressure either.
I would ask to get all of the service records since he doesn't seem to know. Have him fax them over to you.
This truck should still be under warranty right?
Sorry I dont have any info on your problems but I can give you a little advise.
It sounds like he cant sell it for a few reasons.
1. might be he's asking too much. So with that in mind unless your getting a killer deal on the price which by assuming he's had it on his lot for months it sounds like NOT.
2. multiple fuel pumps and injectors...sounds like someone doesnt know what their doing, maybe he took it to Joe Shmo mechanic.
I bought an out of state truck and I made damm sure it was exactly what I wanted, and knew everything about it before I flew to Texas and was going to drive it 2,000 miles back home.
If it was down the street would be one thing, a plane trip to see a questionable truck is another. and remember this is a Questionable Truck
I'd only do it if I knew the truck was everything I wanted and babied for like mine was.
Good Luck
Good Luck
