Window Seal Replacement
The sun has taken its toll on the window seals and has warped them pretty good. I want to replace them, and have looked on dodge parts.com and LMC, but can not find them. I'm not even sure if they're called window seals...
Does anyone happen to have a part number and/or place i can buy them from?
here's the part i need, it's the rubber molding at the base of the window opening (red arrow pointing to warped area)
Thanks!
Thanks!
I found what i was looking. Here's the part numbers for all weather the stripping / door molding / window seals for the mega cab incase anyone may need it down the road
pdf
Did em this morning. Took all of about 10 minutes a side...and that's taking your time. oh and they were actually 36 bucks a piece.
Here's the part numbers.
55277030-AD
55277031-AD
Remove screw on inside of door. Pull seal up. One side came out easy. The other i had to use the screw driver to unhook it from the door. No need to remove interior door panel. I took it off to take a look at the speaker.
new seal
55277030-AD
55277031-AD
new seal
b.lee (12-07-2016)
Rednecktastic
08-29-2010 11:26 PM
raven392003
10-29-2007 11:39 AM
ed cloud
01-13-2005 10:07 PM
