Why would a caliper rub a wheel?
Assuming a stock 17" wheel and a brake system in good working order, why would a caliper rub the inside of a rim all the way around?
I found rub marks on the inside of the stock wheels (removed for H2s). Each wheel indicated contact with the caliper. Two rims were light brushing, one a little heaver, the fourth looked like solid contact all the way around. I crawled under the truck and grabbed the calipers to see if there is any movement. But there is none, they feel snug. Looking at all four calipers now and the current rims, there is plenty of clearance and there are no new rub marks.
Could there have been an issue in the past? What could it have been?
If the truck was used off road a lot, it may have picked up rocks and other FOD that got wedged in there.
Or possibly the wheels were used on another vehicle that had clearance issues.
As long as you don't have contact now, I wouldn't worry about it too much.
Or, like others have said, could have possibly gotten rocks between the wheel/caliper.
Once I had one of the caliper sliding bolts snap and I could hear it rubbing when I turned sharply, like in a parking lot. When I got home I took a look and saw the rub marks on the inside of the wheel. I took the wheel off and couldnt see anything wrong until I grabbed the caliper and it moved. Upon closer inspection I then noticed that one of the caliper bolts that allow it to slide was snapped off. Braking was fine and if it had not been for noticing the noise I never would have known until something potentially catastrophic happened.
Thanks fellas. I got under and had another look after some drive time this past week. There are no marks on the wheels.
I'll have a look next time I run through mud and rocks to take note as well. I appreciate all the ideas. I don't need parts falling off the truck!
ktmrdr85
50
12-20-2016 11:30 PM
classicpuller
09-15-2009 07:16 AM
OldSmokey
10-19-2006 08:05 AM
