Whoa!!!!!!!!!!!!!!!!!!!
When hauling/towing a load with these Cummins, how do you guys stop them?? I have a 2004, obviously, no Jake Brake, automatic, hauling and pulling about 7500lbs. To stop quick, you would have to stand on the brakes. Jake Brakes sound a little too expensive.
Thanks
Thanks
Both my boat trailers have brakes too. But you are right, these things don't stop as quickly as other vehicles (something about them being heavy ;-) ). And I am not too keen on the anti-lock system either.
With properly adjusted and functioning trailer brakes you shouldn't notice any difference in stopping. Having a decent (non-"jerky") controller helps quite a bit too. I have a Prodigy and love it compared to other (cheaper) one's I've had in the past.
How many miles on your current front pads/rotors?
If you are looking for more braking performance, try the cross drilled / slotted rotors. They dissipate heat much quicker & give a much more linear pedal feel. I also shaved about 10' off a panic stop on both my F150 and Dakota when I had them. I would not hesitate to use them on my 3500, when the time comes.
Some may argue that you are losing surface area on the disc and that cross drilling is only for unsprung weight savings. However, you still have all the stationary area of the pad. Since the rotor is rotating you still have the same swept area that the pads contact on the disc.
You could look into a Jake, as well. They are great for down hill runs & keeping your foot off the brakes & saving the brakes for emergency / city use. There are aftermarket exhaust brake kits that also lock up the TC.
HTH
Tony
HTH
Tony
If my trailer brakes had failed on either of my trailers (12K equipment hauler or 10K+ 5th wheel) I would be rolling through intersections standing on the brakes.
They are not designed for that, anymore than 1500lbs gross weight back there is probably not too comfortable with no brakes
??? G56 on an 01?? Please explain??
Oh and get brakes so you don't slide right into us... A jake is more for highway use and grades, not a replacement for the trucks ability to stop using friction brakes.... Trailer brakes and a good controller are a must IMO
I don't care how good your brakes are, with 7500 lbs pushing on you its going to take a lot farther to stop! I'd get brakes on that trailer as soon as possible. Eventually you're going to run into something or somebody. I couldn't imagine trying to stop my 8000+ lb coach without brakes.
Administrator/Jarhead
I agree with everyone else. Towing w/o trailer breakes is not very safe. I have done it (shame on me) for short trips around town, and I was lucky, but I might not have been. Until you get brakes, you'll have to double your following distance, and anticipate a red light at every green one. Be careful.
So, with all the negitive responses, can anyone give a soultion? Where to get trailer brakes with out having to buy new axles?
Wow,
I think the braking performance of the Dodge trucks is great. I've never had a problem loaded or unloaded. So far the most i've pulled was about 7K. Oh and not to rub your nose in it. But you should really never pull without trailer brakes, wether they are controlled by the truck or activated with the hitch, like on uhaul trailers, there's no exceptions.
