What's that little pump behind the pass side battery?
There's a small pump back there that I thought was the washer fluid pump but apparently it's not. Yesterday that pump started running constantly anytime my key is on and I ended up having to unplug it. It has black tubing running to up under the cowl and T's off to under the washer reservoir so I figured it was the washer pump but even with it unplugged my washer pump still works. The washer pump is definitely in a different place under the hood too. So, does anyone know what this pump is supposed to do? Everything seems fine and I am getting no warning lights or anything...
This all started after I washed the truck and hosed off the engine. I have tried unhooking both batteries for a couple hours but that did not reset anything....
Well, I followed the tubing and it does go into a T where one line goes under the cowl and the other one definitely goes to the CC servo under the driver's side battery. I'm going to let the dealer mess with it. I have a whole list of other things they need to look at anyways including the steering recall..
Thanks guys
Thanks guys
Parts envy.
That's what it is Dodgezilla. Parts envy.
You put those fancy rims on and now the other parts are jealous. Now they will start to fail to get attention.
Never fails, just replace an alternator and your transmission will be right behind.
Are all you guys in the "Goofball Club"???
Getting back on track, I think I know what my problem is. Well, I have lots of problems but I'm referring to the truck issue... While I was hosing the engine off I took a soft bristle brush to my pretty painted valve cover. While doing that I remember knocking the crap out of that "T" fitting right where it goes behind the firewall and under the cowl. Everything seems tight but I am sure I either knocked something loose or I may have broken something under there. I am told that the vacuum reservoir is up under the cowl and that's where the line goes. It's definitely not the pump. It works just fine and it's only running constantly because the truck is sending juice to it. Now to figure out how to pull that cowl off and get to that reservoir......
It's fixed. I did indeed break the line right behind the "T" fitting. I stuck some vacuum hose on it and it seems fine now and the pump stopped running.
Thanks for the help guys...
dieseljrs
05-19-2012 09:40 PM
Hounddog
29
09-24-2007 04:50 AM
hotmopr
10-06-2004 05:46 PM
