whats the easiest way to swap shocks?
I have a pair of bilstiens on the way and Im wondering what the quick and dirty is for removing/installing the front shocks?
Two people and small hands. LOL
I have helped replace them without removing anything else. The passenger side was hard to get to the upper bolts and remove the cap. But it can be done. Once you get the top caps off nothing to it. Some will tell you to remove the wheel well lining to make it easier.
I just did mine recently. The hardest part is getting the shock towers off through all the stuff in the way. Just keep the new shocks compressed until after you put the shock mounts back on. I had to pull my DS battery off too because the top nut was stuck on and I could not get it to come off....
but I didnt know that they could be removed through the top shock tower or if the spring had to be dropped and then the shock removed out the side of the spring bucket
I didn't remove the battery or inner fender or anything, just the towers which I could undo easily from the engine compartment or inside the wheel well (I did my spacers at the same time so had the wheels off)
I bolted in the bottom of the shock then put the tower on with the bolts loose. I got my son to cut the retaining strap around the shock from underneath and as it expanded guided it into position into the tower (if that helps).
BTW, you asked a vague question, Mocho trying to help you!
Yea no worries, I just figured if you asked that maybe you weren't sure. I always found it easier to get rid of the straps first. Lower the shock in full length, put the bottom bolt and top in, then push down on the top with the tower attached. Never had any problem compressing it. But there are so many different ways to do it and all work fine.
My top shock nuts were rusted in place also, so removed drvrs side bat. and the tower came out easy. My bisteins fronts had no straps, but compressed nice and steady for ease of assembly.
just wanted to say thanks for the input. got the shocks swapped in.
I just unbolted the bottom of the shock and then unbolted the top shock mount and pulled both the shock and mount out of the truck. then bolted the new shock to the mount and reinserted the shock/mount in to its proper place.
piece of cake
piece of cake
Strong05
21
12-22-2009 12:14 AM
Gman_dodge
09-06-2007 03:27 PM
Bookshelf
03-25-2007 09:12 AM
TxDiesel007
11-22-2006 08:27 PM
