what are the symptoms of a failing injector
what are the symptoms of a failing injector ??when i am in tow haul mode going up a long hill up to where i live i have the truck running up the hill at about 30-35 mph and at about 2000rpm .. and ever so often it will have a slight miss .. nothing to bad but i don't think that is right .. and if i HIT IT wot it seems to clear up .. i am sure if i brought it into the ******* they would say it is fine .. but i don't think it is .. happen also when entering the freeway .. thanks for any info
Gary
Gary
thanks for the fast reply .. well i have no white smoke at start up .. i have tried additves etc. but they don't seem to clear the problem either .. like i said it is very subtle but it is there .. almost like a gas engine missing when under load .... hmmmm
Originally posted by TurboTed
Injector pump?
Injector pump?
Have you checked to see if your mileage has decreased? That's usually one of the first signs that something is wrong.
You said you tried some type of fuel additive - have you tried both Howes and Power Service? If so, you may want to try adding a much larger dose.
It's interesting since it seems to work fine under certain conditions - so I would think an injector is fouled up, vs failing. But that's just my best guess.
Before bringing it in, maybe wait till the next time you take a long trip towing something - if you really make the engine work, higher rpms under load, it might clean itself up - assuming it's fouled up.
Originally posted by AaronT
Probably one of the first signs of injector failure is your dealer service department telling you "there is nothing wrong, that is normal".
A leaky injector will give you a longer than normal crank time .....then eventually the truck just wont start up. Water in the fuel is a major factor to failing injectors.
well , i change my fuel filter , every oil change (every 6500 km 4030 miles ) and i have been running howes and power service these 3 things dont seem to help it ... ... it seems to start fine .. but runs rough when i first start it in the morning . but once it is warm it idles nicely ...well i have to take it to the ******* again to get the weather stripping replaced AGAIN !!! so maybe i'll tell them about it ... i know they'll say it's fine !! anyway thanks for all your you guys !!
Gary
Gary
I'd throw in my .02, but I'm a dealer tech so you obviously don't want hear anything from me.....and you're common rail setup doesn't have an injector pump, but rather a high psi pump to keep the rail charge at spec.
now why would you say that ??? your just the guy all of fus would love to hear from ???!!! if you have some info please do tel ??? then it gives us some info that might be able to send our dealers in the right direction ??!! thanks for any info !!!
blwnsmke
07-24-2008 04:12 PM
LJRoy
16
09-23-2006 07:52 PM
