VEHICLE SPEED sensor output for aftermarket Nav unit
go to www.dodgebodybuilders.com
and down load the files, and open 8W-80, and it has K75 as the VSS circuit.
K75 18DB/OR VEHICLE SPEED SIGNAL NO. 1
K75 = PCM circuit # 75
18 = 18 gauge wire
DB/OR = Dark Blue / Orange
VEHICLE SPEED SIGNAL NO. 1 = Noun name of the signal
CIRCUIT IDENTIFICATION CODE CHART
K - POWERTRAIN CONTROL MODULE
WIRE COLOR CODE CHART - COLOR CODE COLOR
BL BLUE
BK BLACK
BR BROWN
DB DARK BLUE
DG DARK GREEN
GY GRAY
LB LIGHT BLUE
LG LIGHT GREEN
OR ORANGE
PK PINK
RD RED
TN TAN
VT VIOLET
WT WHITE
YL YELLOW
* WITH TRACER
DESCRIPTION - CIRCUIT FUNCTIONS
All circuits in the diagrams use an alpha/numeric code to identify the wire and it’s function. To identify which circuit code applies to a system, refer to the Circuit Identification Code Chart. This chart shows the main circuits only and does not show the secondary codes that may apply to some models.
someone can put this in the WIKI or FAQ or whatever.
it took me forever to find it....
18 = 18 gauge wire
BL BLUE
BK BLACK
BR BROWN
DB DARK BLUE
DG DARK GREEN
GY GRAY
LB LIGHT BLUE
LG LIGHT GREEN
OR ORANGE
PK PINK
RD RED
TN TAN
VT VIOLET
WT WHITE
YL YELLOW
* WITH TRACER
8W-80 is the connector pin out, of all connectors
if you have not downloaded those PDF wiring diagrams, from the dodgebuilders site, i would recommend it, because they only keep 3 years worth on there.
is it found on about 4 connectors
it's pin 22 on C130 (the BIG connector under the dash)
mikelr
03-02-2007 08:30 AM
BigDan
10-07-2006 05:33 AM
PASSMORE
09-07-2006 09:49 AM
jlells01
11-23-2004 03:21 PM
