Turn on AC, it doesnt smell to good
Old 09-16-2005 | 01:01 AM
tacook's Avatar
I have 900 miles on my 2005 2500. Any reason when I turn on the AC, it smells musty................like dirty socks hahahaha
Do I need to check something? It seems to go away after driving for a bit.
Thanks for any suggestions in advance.
Old 09-16-2005 | 01:17 AM
Its All Good's Avatar
The smell you are describing is coming from your vent system, when you run your a/c is it in recirculation mode you need to turn your a/c button off and switch the *** on the a/c panel back to fresh air mode, let the air blow through the vents about a couple of minutes before you shut down your truck, this will let the moisture disapate from your vent system. This should clear up that musty smell.
itsallgood
Old 09-16-2005 | 08:29 AM
J BODY's Avatar
There is a spray called Ozium that works pretty good for covering the odor. With the a/c on recirc shoot a little spray down by where your passengers feet would be (lower dash, you get the picture..) and the hvac will pull it in. I also agree with IAG, running on recirc alot will cause odors.
Old 09-16-2005 | 08:38 AM
P.J's Avatar
P.J
I saw some stuff on two guys garage that you can get. It is an upsidedown foamy type spray that you shoot directly up the vent tube (or whatever, the one that drips everywhere). Let it sit for like ten minutes, then run the AC on MAX for a while. Sounded like a great idea to me, the wifes car will make you , shes a smoker and it's quite sick when you first turn it on.
By the way, I'm That Guy who won't let anyone even think about lighting up in my truck. Eating and/or drinking, ......maybe on a long trip.
Old 09-16-2005 | 08:47 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
Interesting. My truck has the same smell. I thought it was just me.
My A/C stays in recirc all the time.
Old 09-16-2005 | 09:59 AM
PHX_ATC's Avatar
Quit farting.
Ozium, fresh air into AC system, all the above works. When I shut mine down (rather, when my wife shuts it down) I usually leave it on fresh air instead of recirc so it pumps dry air inside.
Old 09-16-2005 | 10:40 AM
Hoss's Avatar
Does that still work if the outside humidity is high? Sometimes I think pumping in fresh air would be about like pumping in water.
Old 09-16-2005 | 11:16 AM
PHX_ATC's Avatar
I live in AZ, so the air is always dry.
I dunno the answer, try it and see.
Old 09-16-2005 | 12:12 PM
billyrae's Avatar
If the interior of the cab is too hot for "fresh" AC to cool, the truck automatically turns on "recirc", no matter which you have selected(in the manual). If the exterior humidity is high, running "fresh" is a bad idea as your cab humidity will remain high and the unit is more likely to freeze up with condensation. Switching to "fresh" for the last few minutes gets rid of moisture in your system and prevents mildew from growing, which is what stinks at next startup.
Old 09-16-2005 | 11:08 PM
tacook's Avatar
Its still been almost 100deg and dry as heck here in Phoenix. Didnt think moisture would be a problem. Ill try the recommendations above..... thanks
Old 09-17-2005 | 09:06 AM
rossn2's Avatar
Just turn the A/c know off and put into "outside air" about a mile or two before you get home. Gives time for fresh air to circ thru the vents. You can also spray "Lysol" down the outside vents by the windshield. I have had the same smell on a F-150 develop. My wifes Hyundai Santa Fe is starting too at 20k miles...It's this blazing heat and humidity in Texas!
Old 09-17-2005 | 08:50 PM
nickleinonen's Avatar
my vent system doesn't smell at all really, but you can really smell it when you use the windshield washers. that stuff stinks. i don't know if there is something growing in the piping or it is the fluid in the resovoir... [i've only gone through maybe 2 gallon since new, so there would still be some oem stuff in the mix]
Old 09-18-2005 | 09:15 AM
rossn2's Avatar
The windshield washer nozzles spray directly over the outside air intake vents below the winshield..Yes, the stuff use to burn the heck out of my eyes too. Had to learn to turn the fan off when using the ww.
jay_d
10-19-2009 10:36 AM
diesel_man98
06-04-2008 10:00 PM
haftrek
08-06-2007 08:35 PM
Cowboy_Customs
04-19-2006 12:15 PM
Journier
02-04-2005 11:02 AM
Quick Reply: Turn on AC, it doesnt smell to good
