trailer brake lights
ok ive had this problem before and had it fixed now its back
driver side trailer brake light not working and its not the trailer, truck lights work fine. 7 pin plug no light or the 4 pin so does anyone have a wiring diagram for trailer wiring for the ram?
dodge fixed it before, but i hate bringing it in rather do it myself
thanks in advance
thanks in advance
Check the fuses under the hood... if the fuses are good then it is going to be the Power Distribution Box that the fuses plug into...
$250 for the part and about 20 minutes to change it out...
Oilguy
Oilguy
I don't know if this is what your looking for but here is the diagram
http://www.tridenttrailers.com/trail...ng-diagram.htm
I thought I'd add to that I had a similar problem. Lights would work for a while and then out. It ended up that the contacts on the lights and sockets were corroded. I cleaned them off and haven't had any trouble since
Have you checked ALL of your grounds, no tjust the tongue? I have the LED lights on my trailer & the white wire grounds to 1 of the studs that mount each taillight on. Apparently I had some corrosion on the hole when I installed it so I had a heck of a time finding the issue. I ended up moving the ground off of the stud & mounting it beside it w/ a tapcon.
Here is a list of threads that have the same exact problem... see if this helps...
https://www.dieseltruckresource.com/...=trailer+light
https://www.dieseltruckresource.com/...ad.php?t=88445
There seems to be a common thread.... Power Distribution Center
Good luck
Oilguy
Good luck
Oilguy
Sorry to interrupt, are there any consistent problems between the 4-way plug & the 7-way? My lights all work on my 7-way, but for some reason my 4-way acts up inconsistently.
OG
no problems with trailer,all grounds good .hooked it to my other truck all good,i hooked my other trailer up to my truck same thing, no driver side tail on trailer only. checked all fuses, good. ill read those other threads and see what i come up with. when the dealer fixed they soldered something just dont know what and where
i had that same problem awhile back and found the 7 pin to be the culprit. changed outthe plug on the truck and works perfect know and has for some time too.
polaris800sp
11-13-2008 05:35 PM
proudpapa97
05-04-2008 06:50 PM
CHarlan
08-06-2003 08:40 PM
