Track Bar installation
Anyone in Nashville area expereinced or know of a good shop to install a custom track bar. I am a little concerned with all the post with the DW on a new 43k truck especially with my wife and 18 month old little girl using it as much as I do. I am wanting to go ahead and get this taken care of.
Looking at my Thuren bar that I haven't installed yet (waiting for the lift) it looks like it is really easy to do. Just remove the old one, adjust the new one to the same length, then bolt it in. Looks like a piece of cake to me...am I missing something here?
Installing a track bar is fairly straight forward( I have installed several on my Jeeps). The main ? is are you just putting a heavy duty one on for the hell of it, or did you do a lift, too? If no lift, measure old one eye to eye & if the new one is adjustable make it the EXACT same length. If you put a lift on, do you need a drop bracket, too, to reach proper angle. No matter what, you will need to get an alignment afterwards. HTH
The track bar locates the axle on the latitudinal axis (side to side). If you take the old out and put the new in with the exact same length no alignment should be needed if you're not lifting the truck at the same time.
They arent hard at all to put on. Did you get an aftermarket one or a stock replacement? Let me know if you need any help. I could probably put it on for you and then you could get it aligned somewhere.
Originally Posted by LFD2037
If you can do it w/out getting an alignment afterwards, your lucky. Rarely will they be the exact same length i.e. w/in a 32nd of an inch.
Thanks for the offer. After it gets in, I will take a closer look at it.
If I need you, i will yell. Where do you live in Nashville?
Originally Posted by tauberson
I am planning on getting the one from http://www.thurenfabrication.com.
Originally Posted by ptgarcia
That's the bar I have. Don thinks I should have my shocks, towers and springs sometime next week. Once I get it everything will go in at once. I'll let you know how easy it is to install.
That's the bar I have. Don thinks I should have my shocks, towers and springs sometime next week. Once I get them everything will go in at once. I'll let you know how easy it is to install.
I live in Crieve Hall off of I-65 and Harding. Ive got a lot of friends that live in Brandywine Point though which is in Old Hickory so im over that way quite a bit.
CTD2001
08-22-2009 10:03 PM
angleiron
03-31-2007 03:58 PM
