Towing Limits??
Towing Limits??
Im about to purchase a new dually. Rams these days have a 23-24,000 gcwr. Which leaves around 16-17,000 pounds for towing. Im starting up a car tote biz and my avg load will be 20,000. I do plan on getting my CDL within a year so I can move up to a bigger truck maybe like a F650. ( no worrys. i wouldnt buy 1 with the 6.0 or 6.4.)
ANYWAYZ, my total weight with trailer will be around 26,000 pounds. I will have proper insurance and blah blah blah, but im breaking the rams gcwr everyday. What were to happen if I were to get caught at a weighh station or if i were to get in a wreck. I will be towing by gooseneck!! Any info would be nice on how rams duallys do this all day long. Does it work like dont let DC know im toting around 20,000 pounds and dont tote more then 26,000 on the highways cause of DOT purposes without a CDL. Kinda like a catch 22?? PLEASE HELP
DOT takes the GVRW from your truck and trailers both and adds them together. That being said your going to have to get your class A CDL if your load is 20k including trailer weight because your total GVRW will be 31000LBS or so. It doesn't matter what you have tagged your truck DOT doesn’t go by that. Anything over 26000 LBS GVRW truck and trailer combined requires CDL class A in combination. If your truck is 11500 GVRW then your trailer has to have a 14500 GVRW to get around the 26k weight restriction. That would only allow you to run 2 cars or small trucks at a time. I run 48' flatbeds not car haulers so talk to some of those guys and see how much the trailer weighs empty and how many that load. Good luck on your new line of work.
Mark
Mark
tow
Mark
Mark
Just chiming in here kinda blindly...
If your tire ratings are high enough, the limit of your GCVW would be your axles, Bags needed of course and good trailer brakes.
But if the F650 has the same engine as our Dodges what is the advantage to the F650 other than not needing to upgrade the suspension?
If you haul trailers that are obviously commercial (multi car trailers) in CA you WILL get caught ($10,000 fine). Trust me, I get stopped by CAHP DOT enforcment at least every other month here in Socal and I'm legal!!. The best thing to do is figure the max GVW you will be rollin at (it sounds like about 36-40k for you), get your class A and register the truck for 40,000lbs GVW, it'll cost around 4-5,000 a year to get the truck registered but they give you a cool little "CA-40" sticker for the side for your doors!!!!
As far as the truck is concerned i would not be worried about overloading it as long as you are equipped for the extra weight (bags or springs or both and brakes!!!). I regularly pull goosneck flatbeds that weigh 25-30K in my 04.5 3500, after a run in with the CA Highway Patrol DOT division a couple years ago I got my class A and the truck is registered for 40K GVW. The only other thing they seem to care about is the sidewall weight ratings of your tires. Good Luck!!
Gearing (some will say that's not an advantage)
Suspension (as you mentioned)
Tires
Allison option (I say that's not an advantage)
etc...
