Tires
Tires
I have some questions about tires? My truck came with the Michelin 265's this is a good tire on the road. I work off road a lot on construction areas new neighbor hoods lots of lose dirt and medium mud. I do not want a mud tire but something more agressive than the BFG. Dunlop makes the Radial Rover RV would be a great tire for me but it is only a 6 ply tire and does not have more than about 2300 lb load range on it. Will these hold up under the weight of the CTD and a 7000 # trailer? If any body knows of something else or if this will work I would be greatly appreciative for any info.<br><br> Thanks
Re:Tires
No.<br><br>3,000 is the minumum you'd want to get, and that is pushing it.<br><br>Best thing is to stay with an "E" rated tire, but you can go to a "D" if it will carry the same weight.<br><br>My BFG's are "D"s and will carry 3195 at 50psi.<br><br>I don't tow anything, otherwise I would have paid a bit more and got some PJ Dirt Grips, as they are "E" rated.<br><br>I will be getting PJ's next time I buy tires.<br><br>There are numerous tire threads with many good suggestions floating around here.<br><br><br>phox
Re:Tires
Given my off road use, I have been looking into this too. My understanding is we have two "E" load range choices i.e. the OEM BFG Rugged Trail (NOT BFG KOs' unfortunately) or the Michelin (parent company) A/S (highway tread). There may be others I am not aware of. What we need in the OEM size "E" load range 17 inch is in order of my preference: Toyo Open Country A/T, Big "O" A/T or BFG KO A/T. I hope that one of these manufacturers gets a green tire ready for us soon. [undecided]
Re:Tires
Thanks phox I did a little research on the pj dirt grips and it looks like a nice agresssive AT with an E load range. Just what I was looking for ;D. Do you know how many miles they will go? There is no body around me that sells them, but I found two places I can order from. <br>
Re:Tires
[quote author=VPI link=board=17;threadid=17325;start=0#162145 date=1058752296]
[/quote]
I don't know how many miles.
I would assume, since they are a heavier rated tire that they are made of a harder compound, therefore should last longer than the BFG's, them being lighter so should be softer.
They are the only ones I could find that come in "E" ratings in larger than stock sizes,
and 17 inch versions for the '03's.
phox
[/quote]
phox
Re:Tires
WOW PHOX I was gonna chime in and say that Nitto was making the 265 in a 17 that was an "E" but after I went to their website I saw that that size is one of two sizes in the Terra Grappler that is not an "E".<br><br>I can't testify to the lifespan on the Parneli Jones Dort Grips but I love mine and they are wearing great. I like them so much I put them on my daughters Tahoe last week also.<br><br>Time will tell on "lifespan" but they are wearing great and ride awesome for 36".<br><br>They look like they should be alot noisier than they are also...
Re:Tires
Correction it appears that the 305's are the only Nittos that are "E" rated according to an ad in 4Wheel&OffRoad Magazine<br><br>Sorry
Re:Tires
Super Swamper SSR's come in 35/12.50/17, 37/12.50/17, and 38/15.50/17. Not sure on load class, but they're all rated to 3,640 lbs. Hope that helps.<br>Chris
Re:Tires
I have some SUPER SWAMPERS in 16.5's I would sell CHEAP!<br><br>Had to have them... HATED them! But man I didn't even need 4wd much ;D
Re:Tires
with all the fuss about E load ratings, I decided to follow up on a hunch. sure enough:<br><br>-- stock 265/70 E rated michelin tires are rated at 3195 lbs<br>-- 285/70 D rated BFG AT KOs are rated at 3195 lbs<br><br>think weight in lbs, not ply rating, and you'll be all smiles! All you gotta do is jump up to a bigger size and your load ratings are solved. BTW I think the BFG MTs are similarly rated (within 100 lbs I think). <br>
Re:Tires
Thanks for all the input. I have not yet made a decission but I have a few choices. I am leaning toward the PJ dirt grips. Very expensive but better than getting stuck in the mud.
chrisminx
14
07-07-2010 06:48 PM
1320
05-29-2009 10:24 PM
sakisaki400
23
12-31-2006 10:17 PM
