tach wire
On pcm left side of engine under intake manifold. I removed left front tire and inner fender shield to get to it. There are two connectors on PCM, the wire you need is in the connector on the left. I had to remove one 10mm bolt up about a foot on the harness to get enough slack to solder a wire to the tach wire. My diagram says orange plug pin 34. I thought it was the third row down and forth wire from the left, blue with a grey tracer. Good luck
Also, thought I would mention for people looking at this later. there are two connectors on top of the intake manifold. 4 wires each. the one closest to the front of the truck has a brown/blue wire. This is also a tach wire. easier to get to than the other one.
TPilaske
16
11-22-2002 08:15 PM
