Sway Bar Replacement Bushing size???
I Have a 2004.5 RAm 2500 4X4 Quad cab that I need to replace the sway bar bushings on. They appear to be about 33mm in size. I can not find an actual listed size for the right bushings. All I can find is bushings listed by size and not the actual vehicle. Or I find the vechicle, they have 4 different sizes listed.
If you replaced yours, what size did you install?
The sway bar is 32mm, the same as the 2001 & 2002. I used these Energy Suspension bushings and endlinks. As a plus the bushings are greasable.
http://www.energysuspensionparts.com....asp?cat=10371
on my 04.5 2wd they were 30mm bushings got poly set off ebay with end link bushings for $30 shipped. Had to check mine with calipers to make sure because of different size listings.
NWJETBOAT,
Did you get mounting brackets with the bushings? If not, did you have to drill and install zerk fittings?
The picture they have up is a general picture and not part number specific. It does not show a grease fitting.
My sway bar measures out to 32.6MM. I would like to install greasable bushings and any information would be appreciated.
NWJETBOAT,
http://store.summitracing.com/egnsea...=KeywordSearch
bigragu
02-22-2010 10:51 PM
tcr
12-04-2007 12:15 PM
