Stolen Truck Recovered
Good to hear you got the truck back. Sounds like it was left in SW or SE as where most of the vehicles end up. I lived in NE for a while in what they call a "transitional neighborhood" and it was all too common to see stolen vehicles racing down the roads. Even saw vehicles get side swiped. Anyhow - I would have it flat bedded or towed to your dealer (if you still use the dealer and yes I know it could be expensive - USAA may cover it) and have them go over it when they fix the steering column and the door.
anyhow - hope things work out.
Sounds like they stole it for a joyride.
If it was parts, they could have had the H2 wheels, among all of the cummins stuff.
Or they being the idiots they are, didn't realize it was a diesel, drove around thinking it was a Hemi with realllllllly bad detonation and rod knock, and got rid of it.
Being as how the tank is empty, it would be a good guess, they didn't fill it with fuel. If it was dead and full of fuel, then I would be worried.
Originally posted by chrismez
Congrats on getting your truck back....Interesting thing is that Dodge Rams are not very popular vehicles to steel....Honda & Toyotas top the list every year...You can get the grey key and kill switches but if the A!$hole wants your car bad enough they will take it. LoJack blows don't bother. Only good one is Onstar. They track the vehicle while its moving and give the PO PO updated locations.
chrismez said,
"You can get the grey key and kill switches but if the A!$hole wants your car bad enough they will take it."
Are you talking about the SENTRY KEY? This is from the 2004 owner's manual--sounds like you would have to bring your own PCM and plug it in in place of the other to drive this truck away. Of course, it can always be towed away.
SENTRY KEY -- IF EQUIPPED
With this system, an electronically coded ignition key sends a signal to the vehicle electronics. If the electronics recognizes the signal, the vehicle will start and continue to run. If the system does not recognize the signal, the vehicle will start and run for a maximum of 2 seconds after the initial key ON. After six unsuccessful attempts at starting, the system will shut down until the correct key is used. . . .
SSminnow
18
08-25-2006 11:18 AM
sjester
12-05-2004 12:27 AM
