Steering wobble after stabilizer install
After installing my skyjacker 2.5 lift I decided to install a steering stabilizer since I will be adding some 35's soon. A couple times on the highway I have hit a pot hole and the front end seems to wobble and shack bad for a second till I slow down. I have re-checked everything in the front end and it is all tight and no problems that I can tell of. Is this because I am still running the stock tires? Not sure what else to think.
thanks
thanks
Sounds like you have the dreaded death wobble. Do a search and you will find all sorts of DW stories. Probably more to do with overall front end condition than new stabilizer. A 2.5in lift probably doesn't have a trackbar relocation bracket, but i would re-check your track bar bushings/ mounting bolts and also ball joints. People with some load range D BFG tires reported DW going away when changing them out but if your running factory load range E probably not the tires. Good luck!!
I didn't know what else would cause it, because it never did it before I put the lift on. I did not realize it was such a big issue with some trucks. Gonna try putting the bd box stabilizer on to start and go from there.
thanks
thanks
Have you had it aligned after you installed the lift. If not I would guess that something is a little off, or the lift is magnifying something on the front steering/suspension that is a little loose that you didn't notice before the lift.
I was going to get an alignment after the lift, but figured I should do it after I install my new wheels and tires. I will be installing a set of 325/60/20 hankook dynapro's in a couple weeks and an alignment will be one of the first things I do.
Thanks
Thanks
macattack_ga
24
05-06-2015 03:11 PM
725Gus
03-06-2014 09:49 AM
tanderson2002us
04-06-2010 01:38 PM
13ALPHA
07-08-2008 11:31 PM
Turbo Deeezle
11-21-2006 10:47 PM
