steering!!!!!!
it is just a little drift it is like the wheel is back forth a little bit i can take my hands off of the wheel and it will go stright just want to know if i change my steering stabilizer will that help.
I also find I am always moving the wheel left, right, left, right, etc. I can't ever hold it in one place for more than a second or two. I did recently rotate the tires and found it to be much better.
You might also want to check your tire pressure. If it's too high, vehicles tend to wander more. I run 65 psi front and back due to having nitrogen and not wanting to fart around with the pressures with or without a trailer. I will try running about 45 psi in the fronts once winter hits. Just to see if it helps with the steering. Maybe 65 in the fronts is too high even though that is the recommended pressure.
LanceK
13
07-14-2006 08:08 PM
ocsurf16
03-13-2006 09:24 PM
unioncreek
06-29-2005 02:00 PM
OHFarmboy
02-25-2005 11:30 AM
06-05-2003 09:27 PM
