Spring Rate
Spring Rate
G'day all,
Presently driving an 04 3500 dually, HO, all the options except "fanny furnace". I need to know what the rear leaf spring compression ratio is, ie, how much will the rear of the truck drop for a given weight. The 01 Ferd 350 dually I HAD, would drop aprox 1 " for every 650# that was put into the bed.
Thanks in advance for any/all replys
Geof ;D
G'day all,
Geof ;D
Re:Spring Rate
This may help somewhat.
I have the 3500 SRW and my 5vr causes the rear to drop approximately 3 inches with the 5vr on. The added weight is 1400lbs as loaded.
I hope this helps :
I hope this helps :
Re:Spring Rate
the rate is going to be progressive due to the overload spring so initially it will drop alot till the overload springs hit then less sorry i cant give u any numbers when i had my trailer on about 500lbs toung weight it didnt move needed to get a new receiver that was lower...
YounanDiesel
10-27-2011 09:00 PM
Pooter
07-24-2007 01:45 PM
cjones42
05-30-2006 10:08 AM
