spicer ball joint question-which ones???
need upper and lower ball joints. spicer lists four different types of upper ball joints!!! 1) non-adjustable 2) adjustable, 1/2 degree positve/negative camber/caster.3) adjustable,1 degree and 4) adjustable 1 1/2 degrees! which ones do i need.should get???? thanks.
It sucks, but I did it with 2 alignments. I had the truck aligned, then took those specs to order the correct offset. Then had the toe re-adjusted after the ball joint work. I believe that is the only way to correct a camber problem though. You could be taking a chance getting the 0 offset and then having it out of adjustment.
I am running a 1.5* left and a 1* right. My tires have always been off regardless of lift. The drivers side you could see the camber by looking at it. They spin to adjust so you can use them to address camber or caster. With the way these trucks are setup I don't think a lift really has an effect on camber. Everything is square now.
wcbcruzer
22
04-30-2008 06:58 PM
B.A.Ram
02-14-2006 09:41 PM
Tim9712v
01-24-2005 05:22 PM
