speaker wire color (+ -)
Old 10-28-2003 | 08:14 PM
cwg's Avatar
cwg
i'm replacing the factory 6x9's and 5.25's with MB Quarts and would like to know what color wire's are postive and negative (all 4 corners) before i take the panel's off. mine is a 04. thanks in advance
Old 10-28-2003 | 08:53 PM
Mexstan's Avatar
Re:speaker wire color (+ -)
Checked my '03 manual and here are the colors:
Left rear WT/RD + WT/BK -
Right rear TN/VT + TN/BK -
Left front door LG/RD + LG/DG -
Right front door LB/VT + LB/BK -
If you have the premium system the colors are different. Hope this helps. Presume the '04 is the same as the '03.
Old 10-28-2003 | 09:03 PM
cwg's Avatar
cwg
thanks but an 04 must be different. i just pulled off the left rear panel and there's gray/ green and white/ green? i can't find my fluke, so tomorrow i'll grab one from work and check it with the speakers disconnected and the volume cranked up. sometimes you can get a postive and negtive reading that way.
Old 10-28-2003 | 09:13 PM
Mexstan's Avatar
Went back and checked all systems and in my manual there are no speaker wires with a green trace. So presume the '04's must be different. With your meter I think you can figure it out.
Sorry I conld not help.
Old 10-28-2003 | 09:46 PM
RamDan03's Avatar
[quote author=cwg link=board=17;threadid=21651;start=0#msg202851 date=1067396607]
[/quote]
My '03 has the colors that Mexstan listed. On the '04 I am almost positive that the gray/green is (+) and the white/green is (-). I helped a buddy of mine with an '04 and if I remember correctly that was how we wired them up.
Old 10-30-2003 | 06:48 AM
cwg's Avatar
cwg
meter idea did not work, so i still need the speaker wire color's for an 04. thanks
Old 10-30-2003 | 07:28 AM
DF5152's Avatar
after you have removed ur speakers make note of where the wires came from use a small battery to test speaker polarity. touch the speaker terminals to the positive and negative side of the battery if the speaker moves out u have it wired correctly and the positive lead would have been on the positive side of the battery then go back and match up the wires.
Old 11-07-2003 | 01:20 PM
cwg's Avatar
cwg
well after a week and no luck trying to get the colors through the dealer and even dodge. i went out and bought a radio adapter plug. i pulled the radio out and installed the plug into the harness. the adapter was labeled so i just matched them up. very easy! took all of 15 min. here they are if anybody what's them, but they will only work on 04's.
left front:
(+) green w/ yellow tracer
(-) green w/ blue tracer
left rear:
(+) gray w/ light green tracer
(-) gray w/ dark green tracer
right front:
(+) gray w/ yellow tracer
(-) gray w/ blue tracer
right rear:
turn on: pink w/ yellow tracer
2 grounds: black or black w/ yellow tracer
hope this helps somebody!
Old 07-01-2010 | 09:29 PM
J2Waite's Avatar
I know its nearly 7 years later, but thanks! This helped me too
Old 07-01-2010 | 09:31 PM
madhat's Avatar
Administrator/Jarhead
+ 1000 points for using the search button!!!
mattyfz450
09-16-2009 07:40 AM
samiam4
02-07-2009 05:58 PM
Stainless
02-23-2008 11:01 AM
mt72916
02-01-2005 08:00 AM
TPilaske
16
11-22-2002 08:15 PM
Quick Reply: speaker wire color (+ -)
