Reverse Honk TSB
FYI- this honk feature is a recall-meaning you can thank the safety zealots in our government,tampering or disabling would violate federal law-so usually you dealer is not going to go near defeating it
So what the difference if the door is open or not. I guess big brother thinks it's less dangerous for the truck to slip into reverse with the door shut than it is open. Stupid,stupid,stupid!!!!!!
Yeah, I had just installed a new bumper on my 04. I was backing up to a trailer and hopped out to see how close I was.... I could have sworn i put it in park... Then blammo, nice dent in my new rear bumper.
Even with that, I hate the recall . I've learned my lesson already!
My truck had this from the factory though so oh well. It got me good the other day backing up to the fuel pump, scared the poo out of me, I almost hit the gas instead of the brake!
Tell the dealer your a farmer...haha
My local dealer takes it off the guys trucks who are farmers case they all hate it. They offered to take mine off, I just haven't gone back to have it done yet.
Try that...
Try that...
Well,I took my 05 in to get my high idle enabled and my friendly neighborhood dealer told me that by LAW they had to do the recall Also that it could not be reversed. So now I am stuck with it, but I did hear of a way to bypass it by fiddling with the seat belt chime wires under the drivers seat. Maybe someone will chime in on that.
Guys, you really are over thinking this. It is not designed to honk if it goes into reverse after you left the truck. It is to indicate you are in reverse when you open the door to get out, thus making sure you do not get knocked down by the door and run over. It does not sound if you are in Drive as there is less chance getting run over.
There have been thousands of safety items done since cars and trucks first rolled out of the factory and many of you do not think about it as they are second nature to you. One day the horn will be also be second nature, unless you disable it and get run over since you left it in reverse when you got out, then you are dead and it doesn't matter.
CamperAndy, do you back up to a trailer on a regular basis? I've backed up to a couple, and unless I have a spotter, I have to adjusts at least a couple times. With the dodge (as far as I know) being the only one to have this feature, it is really hard to get used to it as every other truck I drive doesn't have this rediculous feature.
I've been putting off going for the idle-up enable because of this tsb too.
You know horns were installed in the first place as a safety device, so you could warn the little gray hair that was pulling out in front of you that they were about to do something stupid. I don't hear anyone complaining about that but here is the solution for all you guys that hate the reverse with door open warning, disconnect the horn.
Yes I do use my truck to tow and have done so for years. I just wonder why you (and so many others) have to open the door when in reverse? The mirrors are plenty big. If you only need to back up that last inch to get the ball under the coupling roll down the window and look at the ground, no need to open the door. You could also buy one of those hitch aids that clip on your tail gate where you can see the ball or get a back up camera.
I do understand the "safety" aspect of this TSB, but ***, who the hell closes their door just to back up an inch. They are probably going to make me put my seatbelt on to do that too.
an automatic backup warning system....my memory is telling me there is already something outhere....or right, its on every fleet/big rig in existance. A backup horn. The gov't doesn't make me install one on my truck, so why should I have the main horn go off.
i had to take my truck in for a abs recall several months ago and i dont think they did this recall... im not 100% on this but i think i can backup with the door open and it doesnt honk... i guess ill have to go try it out and see. i can normally just back right up the the trialer.
fredbert
379
08-17-2011 11:52 PM
dirt
15
05-02-2007 02:11 AM
reecegr
21
02-12-2007 03:45 PM
