Replacement batteries
Gen III Replacement batteries
What is the concensus on replacement batteries for the Gen IIIs? Both of mine are leaking acid at the posts and I am tired of cleaning and greasing the connections. I am considering Optima Red Tops. Any thoughts or viable alternatives?
Not to start a battery war as this has been discussed MANY times.For OUR trucks many quality batterys out there OTHER then Optimas.The Optima is a good battery if your going to run the Baja or a off shore race boat.(lots of HARD shock)Otherwise regular quality sealed batterys at a LOT less cost perform as good or better.
I certainly don't want to start a battery war either and that is definitely not my intention. I just felt since I was one of the early Gen III owners, that I was also most likely to be one of the first to experience a battery problem. I did a search but did not see much about battery replacement on the Gen IIIs.
I can get a good deal on the Optimas which makes them quite attractive. What I really like is the fact that they cannot leak, which is even better. What other brands would you recommend that are spiral wrapped or gel cells?
bemhoff
46
11-22-2020 10:13 PM
LFD2037
29
03-31-2019 08:49 AM
Lary Ellis (Top)
11-02-2002 01:07 PM
