Recalls for SO
You can also try www.dodge.com click on "owners" at the top of the page, then click on recall notices and then you need to enter the last 8 digits of the trucks serial number.
Power steering line needed weights due to vibration and cracking of fitting.
ECM connector replacement due to corrosion
A couple of flashes for errors in computer,
lift pump replacement if customer complained and or failure.
Injector loose #6 and 1
Injector bad #3
rear axle howling at or above 60mph. (improperly set gears)
defrost door inoperative.
These are the main ones that i rember. I may have left out a few. The thing to remember the first three were recalls. The rest were internal TSB's
Injector bad #3
P Stevens
04-21-2003 09:35 PM
