Quick question about anti theft and the horn...
Hey guys, really random question but this is my first cummins and something that has been bothering me since I owned it is that the horn does not honk when i hit the lock button on my key fob. Is this normal? thanks!
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
OWNER’S MANUAL ADDENDUM
THIS ADDENDUM UPDATES INFORMATION ABOUT REMOTE KEYLESS ENTRY IN SECTION 2 OF
YOUR OWNER’S MANUAL.
To unlock the doors:
Press and release the UNLOCK button on the key fob
once to unlock only the driver’s door or twice to unlock
all the doors. When the UNLOCK button is pressed, the
illuminated entry will initiate, the parking lights will
flash on twice and if installed, the cargo lamp will turn on
for 30 seconds.
The system can be programmed to unlock all the doors or
drivers door only upon the first UNLOCK button press
by using the following procedure:
1. Perform this operation while standing outside the
vehicle.
2. Press and hold the LOCK button on your key fob.
3. Continue to hold the LOCK button at least 4 seconds,
but no longer than 10 seconds, then press and hold the
UNLOCK button while still holding the LOCK button.
4. Release both buttons at the same time.
5. This will allow you to unlock all doors on the first
press of the UNLOCK button.
To lock the doors:
Press and release the LOCK button on the transmitter to
lock all doors. If the ignition is OFF, when the doors are
locked, the parking lights will flash on once and the horn
will chirp once.
The horn chirp feature will be shipped from the assembly
plants activated. If desired this feature can be disabled by
vehicle.
2. Press and hold the LOCK button on a programmed
(i.e. functional) key fob.
3. Continue to hold the LOCK button, wait at least 4
seconds, but no longer than 10 seconds, then press and
hold the PANIC button. Release both buttons at the same
time.
4. To reactivate this feature, repeat the above steps.
Vehicles will be shipped from the assembly plants with
the park lamp flash feature activated. If desired, this
feature can be disabled by using the following procedure:
vehicle.
2. Press and hold the UNLOCK button on a programmed
3. Continue to hold the UNLOCK button, wait at least 4
hold the LOCK button. Release both buttons at the same
time.
Programming additional transmitters:
Refer to SENTRY KEY - IF EQUIPPED (customer key
programming) in this section.
for 30 seconds.
vehicle.
To lock the doors:
will chirp once.
vehicle.
time.
vehicle.
time.
Xonid
17
05-23-2007 09:33 AM
handymantim
25
01-31-2004 06:46 AM
