PUTCO Handle Covers - Unexpected Problem
Well, I decided to put a little more bling bling on the rig, so I got a set of the Putco chromed-ABS door handle covers. Of course, I dry fit each cover after doing the surface prep. Everything seemed good to go, so I went ahead and peeled the 3M tape off and did the install. At this point, they looked really sharp, everything lined up properly, and I was one happy camper. Then, a couple of days later, I discovered that my key no longer works to manually unlock the door handle. I almost always use the built-in button on the head of the key, so it took me a few days to make this discovery. As it turns out, the shaft of the factory key is no longer than it absolutely has to be; in other words, there isn't much clearance between the "head" of the key and the semi-rounded surface of the door handle when the key is inserted in the lock. Between the thickness of the Putco cover and the tape used to attach it to the handle, the Putco cover effectively "pushes" the head of the key about 1/8" to 1/4" out from the door lock, which is just enough to keep the shaft of the key from properly engaging in the lock. Thus, the key won't work in the lock. This isn't a major deal for me, because I don't use the manual door lock very often and could always pry my Putco cover off in an emergency. The problem could easily have been avoided, however, if Putco had simply made a slightly larger hole in the cover where it surrounds the keyhole, thus avoiding conflict with the "head" of the key. Absent a manufacturer fix, the buyer can solve the problem by opening up this hole about 1/4" or so before installing. Beware, however, that you need to do this before installing, because once the cover is on it is almost impossible to enlarge the hole cleanly.
I would do yourself a favor and have a regular spare key made, and modify it so that it will work. It can only be used to get in the door, but if your batterys ever went dead you would be locked out. May never happen, but I guess I just like to cover all bases.
Shane
I know a friend who put these on his Excursion and every time you opened the door with them the handle would stick in the out position and the door wouldn't latch. You had to reach around and slap it shut before the door would latch. He installed them properly, but I don't care how anything LOOKS if it doesn't function 100% correctly all the time... What a PITA !
I'm with ptm600 as well.
My truck is an '03, and my key and keyless entry are separate, as opposed to the 2005's and newer being integral. My regular key works great---no clearance issues at all. I'd just have a regular key available on the same ring to be on the safe side.
Greg
Greg
I was given a set for Christmas, thanks for the heads up. Will bore the hole out before installing the drivers door cover. I had been looking at the billet replacements, was going to put them on when I installed the jimmy jammers.
CD
CD
Greg
Greg
I checked mine and darned if it doesn't work. I was already planning on getting a regular flat key made so now I will definitely do it.
Thanks for the heads up.....
Obviously I'm wrong in the assumption that the 2005 Dodge RAM keys were integral; my wife has a 2005 Jeep Liberty Limited 4x4 CRD and it was integral. I had just guessed they went that way across the board on DC vehicles around that year. I have seen 2006 Dodge RAM keys that are integral.
Sorry for the mis-information.
Greg
Greg
