PSC Steering Brace+Lots of PSI!
Old 04-07-2008, 12:25 PM
coparam4x4's Avatar
Originally Posted by Chazmanian
I bought the "El-Cheapo" PSC unit. If I could turn back time I would have spent an extra $50.00 or so and went with XLR8R's way stout 4 bolt main DSS unit!
When $50.00 is the difference between super stout gonna last forever and as cheap as they can make it work super stout wins in my book every time!
Glad I read this first, I was just getting ready to order the "El Cheapo". I guess now I will save a little more to get the better one. BTW what are the difference's between the 2. Both pics look pretty much indentical. And what are you refering to when you say "4 bolt main". They both look like they are held in place with 4 bolts. Is the PSC that is pictured not what you actually get? Thanks.
Old 04-07-2008, 12:58 PM
XLR8R's Avatar
I bought the "El-Cheapo" PSC unit. If I could turn back time I would have spent an extra $50.00 or so and went with XLR8R's way stout 4 bolt main SSSSS unit!
Our design uses a nickel-plated rebuildable 4-bolt flange bearing with stainless steel hardware, integral sway bar drop mount and powdercoated steel... shipping is included within the continental United States.
Old 04-07-2008, 01:26 PM
HOBrian's Avatar
It also seems as if most BFG Rugged trail tires are sold as OEM Stuff. Does the avg guy go out tire shopping and come home with a set of BFG Rugged Trails? I dont really know.?
Yep, I brought the rugged trails as new tires. Two reasons:
1. I only had to buy three. (used the spare)
2. I got 90,000 miles out of them.
Old 04-07-2008, 02:33 PM
Chazmanian's Avatar
These are the two units....I know which one I should have. I'm equipped with the wrong one! If I could turn back time I would spend the few extra bucks for "The Good Stuff"!!!
I refer to XLR8R's as the "4Bolt main" because its got the 4 bolts holding that bearing on place....Plus it sounds tough as heck and I have a marketing background.
Old 04-07-2008, 02:36 PM
Chazmanian's Avatar
1. How much PSI are you running front and rear?
2.Is yours a 4x4?
3.Do you feel any tire mush or low speed wander with em'?
Old 04-07-2008, 02:58 PM
coparam4x4's Avatar
Yea after XLR8R put his link in, I was able to see the difference. His is quite a bit different from both the DSS unit and PSC unit. I have never seen his before he put the link up.
Old 04-07-2008, 03:03 PM
Chazmanian's Avatar
Yea after XLR8R put his link in, I was able to see the difference. His is quite a bit different even from both the DSS unit and PSC unit.
His should be renamed...."The 4 Bolt main"!!! Still irked that I ended up with cheap autozone looking model instead of the bad-**** one XLR8R has.....
So I'm ordering all his good stuff for my front end...Note how his sway bar mounts are not only super trick urethane but also have those grease fittings on em'. Triiiiick.
Old 04-07-2008, 04:32 PM
megaboom's Avatar
i love my sssss looks killer in the platinum silver!
Old 04-08-2008, 04:10 AM
chipmonk's Avatar
Lost me as well...But how are those Toyos working out???
the toyo m/t's are the most highway friendly m/t's i've ever run. very stiff sidewall, so great for towing and hauling, but definitely should run them at less than max psi, when empty. i would recommend them to anyone looking for a m/t, or even for those looking for an aggresive a/t.
Old 04-08-2008, 06:49 AM
HOBrian's Avatar
2.Is yours a 4x4?
I am running 65 psi in the front and 50 psi in the rear when I run empty. It is a 4x4 and I really don't feel any wondering at low speeds. I did have death wobble with this truck on the stock tires, but after 90,000 miles and no alignment and ball joints that were toast I don't think it was the tires. At least I hope not!
Old 04-08-2008, 08:57 AM
XLR8R's Avatar
Wait 'til you guys see pix of the latest LazarLinks in a few days!
The front endlinks are mounted in double shear, and the rear endlinks have double heims.
03CTDCO
05-20-2009 06:36 AM
Dan_K
12-19-2008 09:38 PM
CTD2001
22
07-27-2008 07:55 PM
D45
30
04-17-2008 07:24 PM
Buckshotram
03-08-2008 12:58 PM
Quick Reply: PSC Steering Brace+Lots of PSI!
