power inverters and outlets
i want to install a power inverter to power my 110V items. my question is, how much power can i get out of the stock electrical system, both on a 1500RPM fast idle, and with out the engine running, with out killing my battery's? i would like to have more than i need, not going to use all of it all the time. could i get 1,000 watts out of it?
i want to place some outlets in the back bumper, and a set inside the cab. one must be easy to get to driving up the road, or from the drivers seat. any ideals?
I have a small inverter in my truck now, handy for chargin the dewalt batteries, and running other things, been thinking of getting a bigger one but keeping in mind what else I have I would use an interrupt switch. This way when you tun one item on of high draw, you can turn the other off, in my case I Isolated both items with 60 amp max draw with switches, and would do the same with a high output inverter to keep a level of power consumption manageable. Mounting the unit under the pass side seat is a great spot, or under drivers seat. Takikng seats out to do the install makes it a lot easier, and the bolt that holds the seat makes a big sturdy ground.
I'm running a 1200w and it's sitting under the driver's seat. The alternator keeps it up, but I wouldn't dare use it much without the engine running. Batteries cost more than diesel fuel (at least for now ).
I've got a 700 watt unit under the driver seat for the boys "toys". A 13" flat screen and video player and an Xbox 360. I won't let them run it more than 15 minutes without the truck running. Great for the RV trips!
I went to Radio Shack and bought one of those cheap 400w inverters and use it in our travel trailer to run a 19" TV/DVD player combo. Works great.
I had an old 3000 watt Statpower laying around so I installed it. Probably would blow the batteries it I used it to its full capabilities. I keep an electric impact tool in the truck with an extention cord and a set of impact sockets for wheel removal incase I have a flat.
