pop noise when taking a sharp left turn
what is this noise? when i go to make a sharp left turn i have been getting a loud pop noise from the left front? Any ideas?
How many miles on your truck? Can you feel anything in the steering wheel when this happens? Have you checked your wheel nuts for tightness? Have you jacked up the front wheels and given them a good shake? When you have it up on the jack, stick a crowbar under the tire and lift up and see if there is any free movement.
My friends 04.5 did that.
They replaced the entire left side suspension (control arms, ball joints).
Still did it.
He ended up getting rid of it, and getting a 05.........problem solved.
Still did it.
My 03 did that after I installed my 2" leveling kit . I tightened everything pretty tight. Well when turning, I got a thump sound only in one direction. Had a friend turn the wheel back and fourth while I laid up front to see whats up. One of the arms I removed from the steering looked loose while moving. I then got the torque from the manual and tightened it..... moved by about a turn and a 1/2. FIXED...no more thump.
I have this problem when turning right...I have a 2wd and alot of other folks have the same problem. We have a 2003 dodge full size van at work and it does the same thing. I just havnt had a chance to get it to the dealership to get it fixed
tndiesel
09-07-2011 12:56 AM
