Polishing Guru's
Polishing Guru's
I need some suggestions on how to get some rust off of the exuast side of my Top charger. Its Polished stainless and I want to clean it up. It sickens me How do you lighlty repolish it
Thanx for the help
Thanx for the help
This is what I use. It works great.
http://www.eagleone.com/pages/produc...=1006&cat=5006
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
0000 STEEL WOOL. the more zero's that is on it the finer it is. used it to clean all the polished stainless on my Pete. then go over with some polish.
They make rubbing compound, swirl remover, and various grades of polishing compound. It can be found at any good automotive paint store. I'm sure there are products which are less expensive, and will work just as well for your application. Try an auto parts store, or silverrams suggestion.
Use Stainless Steel wool if you need too, but I prefer to use some 1500-2000 grit wet/dry paper then follow up with a nice polish.
I think these are all pretty much the same formulation. I used to use the all metal polish to polish jetboats. Its nice because it leaves a nice wax on top...
http://www.meguiarsdirect.com/produc...p?T1=MEG+M2805
http://www.meguiarsdirect.com/produc...p?T1=MEG+M9314
I've seen this at WalMart..
http://www.meguiarsdirect.com/produc...T1=MEG+MC20406
