passenger vents do not blow as cold as driver vents
Okay so I noticed today as it was hot that there is a good 15-20 degree difference in my passenger vents to my driver vents.
I have dual zone climate control. Now one would think that it could not be my charge since the driver side blows cold but I didn't design the heater box so maybe one side has a easier path or something.
the driver blend motor is visible from the front and I can watch it actuate and I can hear the passenger motor actuating and will blow hotter if I turn it hot. it does blow colder with the AC on than off.
my logic leads me to two conclusions.
1. maybe my charge is low and this is a symptom
2. my passenger blend door is broken in some way not isolating the heater core from the cold air.
any body have any tips or advice? should I just go down and have my ac chagre checked to eliminate it as a variable or is there a way to tell if the passenger door is damaged without removing the box?
okay update. took a drive with my multimeter and thermal couple. I think my charge might just be low.
88 degree's ambient
temperature low with ac off
93F D 95F P
AC on
62F D 79F P
heat on
137F D 127F P
seems like It should blow colder than 62 with the AC on full blast.
88 degree's ambient
93F D 95F P
AC on
62F D 79F P
heat on
137F D 127F P
It's a low charge. I just went through this a couple months ago and there have been allot of threads on the subject this summer. Evacuate and recharge, add some dye to look for the leak. Mine took a little over 1 pound.
I went to Wal-Mart, bought a can of R134a with the built-in pressure gauge, ran the A/C on Max for a few minutes, hooked up the hose to the low-pressure connector, put the whole can in, and bingo, problem solved.
That was several months ago and still works great.
This is a very common problem with these trucks, but the fix is (usually) pretty easy.
Yeah bought and 18oz can with a gauge now all vents are blowing ~50f at idle.
I will just have to watch it and do leak test if it does not last too long. I don't mind $20 every five years.
I wonder how long it has been getting progressively worse though. I will just have to measure the vent temps every 6months or so for piece of mind.
Cool...I (passenger actually)just noticed last week mine`s doing the same thing , I was worried it was the blend door hopefully mine will just need a charge of freon
MikeyB
Well , had my system evacuated and recharged and now the A/C blows even less cold than it did before ....in all vents , and the pass. side is still warmer than the drivers side.
I guess I`ll take it to the A/C shop we use at work , and see what they come up with....I didn`t think it could be that easy for me
Spooler
96
05-07-2012 09:11 AM
Raycer
08-11-2009 09:18 AM
case310350
05-17-2009 01:37 PM
clean1ox
08-12-2007 04:12 PM
