Pac Brake Auto Shifter Switch
Old 04-12-2009 | 03:03 PM
KWKING's Avatar
F.Y.I. since I could not find any info on this on this forum I decided to post this for others,as an alternative to the dash switch for use in autos,here is a switch bracket available from Pac Brake for auto trans. equiped trucks Part # C18081..$30.00 Can.. Add your own small toggle switch.Simmilar to the one for mannual trans.Very handy to use.
Attached Thumbnails Pac Brake Auto Shifter Switch-img_0001.jpg   Pac Brake Auto Shifter Switch-img_0002.jpg   Pac Brake Auto Shifter Switch-img_0003.jpg   Pac Brake Auto Shifter Switch-img_0004.jpg
Old 04-12-2009 | 06:25 PM
xtoyz17's Avatar
Has anyone tried using the exhaust brake switch and bezel from the 6.7 trucks yet? Or is not a simple open closed contact type switch?
Shawn
Old 04-12-2009 | 08:12 PM
KWKING's Avatar
Its just single pole switch,you need to ground the input to the ECM to make it work.I've driven the 6.7l and tried the brake switch on it too,I like mine better,just flick it on/off with your thumb,its easy to find witout looking.The bracket could be just a bit smaller ,but its ok.
Old 04-12-2009 | 10:10 PM
HL649's Avatar
Why would anyone shut the brake off. Mine is always on. I actually could live quite happy if there wasn't even a switch - just wired in the always on condition.
So seriously, why do you shut yours off?
Old 04-13-2009 | 06:17 AM
xtoyz17's Avatar
Some people shut them off when driving in the winter. It's a scary situation on a snowy road when the back end comes past the front... I'm sure theres other instances too I'm not even thinking of.
Shawn
Old 11-25-2009 | 01:19 AM
btolenti's Avatar
Shawn
Anyone have a part number for this bezel he talks about? I want to get one to mount other switches on - my stock one is a storage pocket....
Old 11-25-2009 | 08:06 AM
Fisherguy's Avatar
You don't always WANT it on. Going down a hill with the brake on sometimes I'm going too slow, I turn the brake off and use the brake when I need it, plus, as already mentioned going down snowy or icey roads with the ex brake on the rear end tends to lock up.
Old 11-25-2009 | 04:44 PM
bb_94401's Avatar
I leave mine on most of the time.
I will shut it down when in the snow, without chains.
I also will always shut it off when climbing long, steep grades with lots of sharp corners, during the summer. Compressor cycles on/off with each corner. Compressor has a duty cycle of 25% so it will heat soak, with all the continuous on/off cycles and then not work until it cools off (30 - 60 minutes later). The heat soaking is more problematic due to my compressor mounting location at the front of the engine.
If I were to do it again, I'd mount it in the alternate location in the fender well that PacBracke now describe.
Old 11-25-2009 | 04:48 PM
WhiteMule's Avatar
Can you elaborate on the location in the fender well? I will be installing mine in the next couple of weeks and would like to check out this option.
Old 11-25-2009 | 06:44 PM
CD in NM's Avatar
For the most part my PacBrake is not shut off either, but I do shut it off when snow or ice conditions exist.
I am moving my brake off the engine mount, just gets too hot there, and it does heat soak a lot. I was looking at several places that could be good aux mounting points, will have to go to Pac's site and see if they have any technical information on alt mounting places.
CD
Old 11-28-2009 | 06:29 PM
bb_94401's Avatar
PacBrake site has a document in their literature section:
New Compressor Mounting on 2003 and newer Dodge Trucks
which describes how to mount it on the passenger side fender brace.
KWKING
02-14-2009 11:54 AM
CTD2001
10-11-2007 08:38 PM
pet05
04-23-2007 04:03 PM
PADZZ
07-04-2003 08:54 PM
Quick Reply: Pac Brake Auto Shifter Switch
