oil?? synthetic or conventional
Old 01-27-2010 | 10:33 PM
6.7megaman's Avatar
I Would Like Everyone Opionion On Brand Of Oil For Cummins Diesel Is Amsoil The Best Why Or Why Not Synthetic Or Conventional
Old 01-27-2010 | 11:05 PM
Ruralmedic's Avatar
Well, let's answer a question with a question. How about a happy medium? Why not use a blend? A little more cost than a conventional oil, but almost half the cost of a full synthetic. Some say the virtues of synthetic, extreme temperature performance, can be had by simply using a blend of it, and that most motors oils definition is the additive package they're using. Without an additive package, no matter what the basestock is, the lubricating qualities of any oil would be minuscule. And no matter what oil is used, the by-products of combustion are going to be the determining factor as to the oil's useful service life.
I'm not an oil profiteer, just simply a Cummins owner, looking for the best value. Beware of marketing propaganda!
Regards
Old 01-27-2010 | 11:41 PM
Lost Lake's Avatar
Well, you could do a search and read until you pass out.
Everyone has an opinion and most are based on God knows what.
There was a blind test done at TDR and an independent expert rated all the then current oils based on additive packages and whatnot. If you believe him, Valvoline Synthetic Blue is the best. Amsoil comes in quite low.
If you want to listen to Blackstone like I do, they say almost any oil out there is just fine if you change it every now and then. Even the $10 a gallon or $6 a gallon like I was running gave me excellent oil analysis reports. Why spend $28 a gallon and throw it away when you can spend $6 a gallon and get the same oil reports?
If you want to run extended change intervals you may want a better additive package and filter set up. But the cost for your 7,000 mile analysis and quart of replacement oil will be more than my oil costs for a full change.
I'm going to run Valvoline Syn Blue after I get this Rotella 5W syn out in the spring. If I didn't run that, I would run any CI+4 instead of the best CJ oil....
Old 01-28-2010 | 12:32 AM
TexasCTD's Avatar
Originally Posted by Lost Lake
..........., I would run any CI+4 instead of the best CJ oil....
Good luck finding any CI-4+ anymore. I was going to switch to John Deere due to this....and now even it has changed to CJ blend.
I've decided, NOW, to just stick with regular Rotella 15w40 and add a small amount of ZDDP additive to the oil.
Old 01-28-2010 | 02:05 AM
billie's Avatar
Geez, another oil thread
Old 01-28-2010 | 11:12 AM
Lost Lake's Avatar
Even Deere is CJ now???? Rats!!!!
Old 01-28-2010 | 01:02 PM
pdogg's Avatar
oh no.... not the dreaded CJ-4 .... run away!!
Old 01-28-2010 | 06:48 PM
Lost Lake's Avatar
I'll say! Have you done any oil analysis' on it yet??? CJ will kill your engine fast....
Old 01-28-2010 | 07:14 PM
Spooler's Avatar
With a 6.7, stick with Dino oil. Due to fuel dilution you won't gain any extended drain intervals, and that is where the savings is at with Synthetic.
Old 01-29-2010 | 12:27 AM
Dieseljunkie's Avatar
Personally, I'd run the Amsoil Synthetic blend diesel oil. It's cheaper than the full synthetic, but still a great alternative.
Scott
Old 01-29-2010 | 10:15 AM
pdogg's Avatar
I'm on my 4th engine since switching to CJ-4 oil..... I love this stuff...
Old 01-29-2010 | 03:33 PM
BigGrayMegaCab's Avatar
I run VPB 15/40 Dino and have great reports from Blackstone. I am up to 15k change intervals and being told I can go farther. I see nothing wrong with the CJ4 blend.
Old 01-29-2010 | 04:15 PM
Roperteacher's Avatar
Same here, not sure where everyone is getting their info. I have run the Valvolene PB with analysis that come back JUST FINE. I am running the John Deere now as all the places around here are still CI4. No Cj hitting the shelves yet. But I have no problems with the VPB CJ
John Davison
02-20-2014 12:39 PM
Roadstar
01-14-2010 04:50 PM
Roadstar
01-11-2010 07:44 PM
The_Head
09-28-2009 08:37 AM
Hannibal
04-13-2005 04:32 PM
